Home > Maintenance & Mods (L322) > Air Filter
Pedrochellie
United Kingdom 2003 Range Rover Vogue 4.4 V8 Epsom Green
Air Filter
What does everyone think of using a K&N air filter on a Vogue 4.4? Worth the extra £ and does it give a slight performance gain or use OEM??
Cheers Thumbs Up FFRR Vogue 2003 4.4V8 - Epsom Green & Ivory
Ducati 999S
Post #124065 28th May 2012 10:41pm
Stick with the original Thumbs Up
Post #124066 28th May 2012 10:42pm
ebajema
I put a K&N in and to be honest, absolutely no gain whatsoever. Only reason for me is that the normal filters cost more than a K&N over here and Harmatan can be quite dusty so I want to be able to clean them after each Harmatan if needed. MY 2010 5.0 SC Galway green and sand interior!!
Post #124067 28th May 2012 10:49pm
dannyp15
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Alaska White
original Thumbs Up
Post #124220 29th May 2012 7:20pm
daxon
Canada 2005 Range Rover Westminster 4.4 V8 Java Black
Go with original, K&N might be useful for a carbed car but can foul your
air mass meter causing a need for air mass replacement due to the K&N's
need to be oiled.Don't believe their marketing hype.
Post #124732 2nd Jun 2012 2:14am
How about an open sponge type like pipercross, they dont need oiling.
Anyone used one in a ff, had one in the skoda for years now, gives a v slight performance gain. There is nothing that can't be fixed with a hammer😜😜
Post #124737 2nd Jun 2012 9:58am
Pedrochellie
Just seen this:
http://www.ebay.co.uk/itm/200771336023?ssP...1423.l2649
Anyone used one of these? FFRR Vogue 2003 4.4V8 - Epsom Green & Ivory
Ducati 999S
Post #125018 5th Jun 2012 2:41pm
vnitos
South Africa 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Most if not all who did the conversion on 2002-2004 models to 2006 and later are using k&n type cone air filter
Post #125034 5th Jun 2012 4:21pm
Dolphinboy
United Kingdom 2011 Range Rover Vogue TDV8 Atacama Sand
I think that's because space is tight after the conversion and the k&n fits the best. Thumbs Up
Post #125036 5th Jun 2012 4:32pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Run my td6 with a K & N tend to put them on all my cars by habit. No noticeable performance gain but it does seem to change up earlier and seen a small mpg increase only negative in sounds bit louder! Mine was a blue one! Smile
Post #125043 5th Jun 2012 5:29pm
The Brains Trust
Australia 2003 Range Rover HSE Td6 Adriatic Blue
K&N's are only good at keeping small rodents out of the engine. If you actually want to keep dust out of it, stick with the original.
Post #125560 10th Jun 2012 11:04am
