Home > Maintenance & Mods (L322) > window switch rubber coating removal
highfellzippy
United Kingdom 2015 Range Rover Autobiography SDV6 Montalcino Red
hello the window switch rubber coating is coming off my front switch pack is there any easy way of completly stripping them off ??
or do i just pick it off
Post #128058 28th Jun 2012 8:19am
misteralz
Scotland 2003 Range Rover Vogue Td6 Buckingham Blue
Pick it all off. Then get yourself on eBay and buy yourself a tin of plasti-dip if you fancy recoating it. Works a treat! It's basically spray-on rubber and is incredibly useful. I've used it to fix split accelerator pump diaphragms in old carbs and umpteen other things. Smile
Post #128062 28th Jun 2012 8:41am
Knips
United Kingdom 2017 Range Rover Vogue SE SDV8 Santorini Black
@misteralz
Please would you post a picture of the re-coated switch panel. Thanks.
Post #128100 28th Jun 2012 11:56am
misteralz
No, because I've not done a switch panel! Laughing 2003 Vogue TD6/1992 Classic 300TDi/2x 1991 Golf GTI/1966 Volkswagen Kombi/2x 1968 Volkswagen Kombi/Probably something I've forgotten...
Post #128119 28th Jun 2012 12:58pm
EVOeng
Afternoon Chap,
Search google for "Ferrari sticky buttons". It's a very common issue with those cars and owners do tend to use plasti dip as well as other brands. Not sure if you will be able to see images without logging into the various Ferrari forums but I will post pictures of others cars later if need be.
For now, have a look here:
http://www.clubscuderia.co.uk/forum/archiv...40021.html
Post #128125 28th Jun 2012 1:24pm
