Home > Maintenance & Mods (L322) > B pillar black finisher
nubbin
United Kingdom 2019 Range Rover Vogue SE SDV8 Corris Grey
Can anyone tell me how to remove the satin black finisher panel from the B-pillar please? The finish has bubbled up andf I want to rub it down and respray it which is much easier off the car. I've searched around and can't find the answer and I'd rather not do my usual trick of bending/breaking everything I touch!
Post #132306 21st Jul 2012 12:08pm
mjdronfield
Are the B pillars not actually the window surrounds ?
I've got my front one to do, as it is bubbling up around thw window ;
Think the side bit is the same trim, and I understand you access it by taking the door card off, and the door window seal from the inside, to reveal screws for it..............?
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #132315 21st Jul 2012 2:04pm
nubbin
I have the same appearance but on the vertical bit in the picture. I decided to leave it in place and rubbed it down with1200 grit wet and dry, then sprayed it with satin black. Looks perfect again! Cool
Post #132340 21st Jul 2012 6:57pm
mjdronfield
I'm wondering whether that might be easier with mine to be honest.
Not sure how much the new trim would be, but I'm guessing it ain't gonna be cheap......... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #132346 21st Jul 2012 7:53pm
nubbin
I found an example of the trim in various places - only £20 but to be honest, although the finish of the satin spray isn't as smooth as the original, it does refresh the appearance of the panel, and is a good value for money bit of maintenance.
Post #132367 21st Jul 2012 11:02pm
mjdronfield
As the little black strip at the bottom of the window seems to be about £30 odd, I didn't even ask how much for the window surround.
Are there some on the net ?
Not done an exhaustive seach........
£20 doesn't seem bad...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #132369 21st Jul 2012 11:29pm
ollielloyd
United Kingdom 2005 Range Rover Vogue Td6 Java Black
How do you remove this to replace it?
Thanks
Post #146519 15th Oct 2012 10:10pm
mjdronfield
Not done it, but I believe its screwed on from behind, ie you have to remove the door card and seal to get to the screws ........... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #146528 15th Oct 2012 11:18pm
