Home > Technical (L322) > SUSPENSION FAULT! WHAT TO DO?
ENVOY
United Kingdom 2003 Range Rover Vogue Td6 Java Black
I suppose it was only a matter of time before my motor developed a fault which would be displayed on the dash that cant be an easy fix Evil or Very Mad
I a;ways ;eave my car in access mode, yesterday just as i was loading it up and getting ready for a longish drive i noticed that on the dash it said "INACTIVE AIR SUSPENSION" and i could not adjust the suspension in the usual manner! now the suspension was in normal driving mode so i stilldid the trip but on the way home a counter came up on the dash aswell and it keeps counting down then counting up.
Does anybody have any ideas as to what it could be and is it an easy fix, or is it a trip to the Stealers?
Cheers in anticipation of your replies Thumbs Up
Post #9971 26th Dec 2009 9:35am
The doc
2008 Range Rover Vogue TDV8 Java Black
I have this happen a lot on X5's when I've been working on them - there is a fuse in the o/s/r that somtimes needs pulling out and pushing back in - should be in your manual - worth a go and free Thumbs Up '09 Freelander 2 TD4 HSE Auto for the Mrs
Using the works Fiesta 1.6 TDCI Sport Van - CHROME FREE THOUGH
Searching for a nice E63 AMG or S8 V10 to replace my "wonky" TDV8
Post #9972 26th Dec 2009 11:15am
daveo
hi, start the car and let it idle, then turn the stearing full to the left and then to the right and back to the left, it resets it.. it worked for me...
daveo V8 facelift Range Rover Autobiography 22" wheels.
Post #9973 26th Dec 2009 11:52am
RRV
United Kingdom 2015 Range Rover Vogue TDV6 Santorini Black
Envoy,happy Xmas mate.
When I owned your motor that message came up once and then never returned.Also HDC inactive used to pop up now and again.Nothing to worry about I would say,just the cold snap playing havoc with the RR electrics.
Oh yes and last winter the whole stereo system stopped working,sat nav aswell.Cleaned out the NS rear from damp etc and never had a problem since. If you have nothing nice to say,say nothing at all.
Post #9974 26th Dec 2009 12:20pm
andyw
England 2002 Range Rover HSE 4.4 V8 Zermatt Silver
I had that fault before that my EAS was slugish and slow and eventualy gave up and turned off. trip to the stealers Big Cry some time later and all fixed EAS is now like a tric car with the tric suspension EAS is now very fast and no pros so far Razz
hope this helps
merry christmas all Thumbs Up 02 Range Rover HSE Zambezie silver 4.4
Post #9982 26th Dec 2009 3:52pm
Stoich
Got this from the manual
Fault Messages
The air suspension has two methods which it can use to inform the driver of a fault in the air suspension system; the
air suspension control switch LED's and the instrument pack message centre.
When minor faults occur and the air suspension ECU is able to level the vehicle to the 'current' ride height, the control
switch LED's will display the current ride height. When the vehicle returns to the standard ride height and further height
changes are disabled, the 'HOLD' LED in the control switch will be permanently illuminated.
The air suspension ECU suffers a major failure and there is no air suspension control, all the control switch LED's will
remain unlit.
If a fault occurs and the ECU can determine the ride height and the vehicle is not above standard ride height, the driver
will be notified via a 'AIR SUSP. INACTIVE' message in the message centre. If the ECU cannot determine the height
of the vehicle, or the vehicle is above standard ride height and cannot be lowered, the 'AIR SUSP. INACTIVE'
message is accompanied with an alternating 'MAX 35MPH' message. If you like it, who cares what other people think
Post #9983 26th Dec 2009 4:05pm
ENVOY
Thanks guys for all your suggestions, advice and help. No good so far, have tried Daveo's suggestion and had no joy also had a look for a fuse and cant find one! will try disconnecting the battery tomorrow and see if that does anything.
Mine says on my obc "air sus inactive" and nothing else. on the control switch the normal driving position is lit up and the inhibitor light is lit. The suspension is still automactically self leveling as i have watched it but i just cnt adjust it myself so it cant be much to sort it out? hopefullly Rolling Eyes
Post #10014 27th Dec 2009 10:04pm
http://www.fullfatrr.com/forum/topic229.html?highlight=suspension
Post #10015 27th Dec 2009 10:22pm
ENVOY
Well i took the compressor cover off in the boot, couldnt find any sort of valve matching Micks description so i took both solenoid valves apart and had a general look around but could not find anything that looked amiss, put it all back together disconected the battery for half an hour, reconected it and guess what............................................ no f Censored g difference at all, still got the same fault Big Cry Big Cry
Looks like its a trip to the staealers to sort it out Sad
Post #10023 28th Dec 2009 2:54pm
Confused Crying or Very sad All my spelling errorz are belong to me!
2023 FFRR L460
2020 Range Rover Velar
Post #10024 28th Dec 2009 3:12pm
jayzee
2006 Range Rover Vogue SE Supercharged Java Black
Gold thimble sized valve? It may have been removed at some point, as mine was.
Post #10049 28th Dec 2009 11:41pm
ENVOY
Took the car to the garage today to get the suspension sorted, they pluged in the computer and the fault said "not enough air getting to the reciever" They reckon it is down to the very cold temp! whatever the reason its ok now and it works fine! At least it didnt cost me a small fortune Very Happy Thumbs Up
Post #10472 4th Jan 2010 10:52pm
The doc
Thank goodness for that - had me worried for you mate Thumbs Up '09 Freelander 2 TD4 HSE Auto for the Mrs
Post #10473 4th Jan 2010 11:08pm
