Home > Technical (L322) > Timed climate |
Allan Member Since: 15 Aug 2012 Location: Yorkshire Posts: 46 |
Just a low vehicle battery, take it out for a run.
23rd Sep 2012 12:12pm |
Ukdave104 Member Since: 26 Apr 2012 Location: Aberdeen Posts: 116 |
Thanks for that Allan, I'm guessing then that the daily commute to work of 5 miles each way isn't enough to keep the battery topped up
23rd Sep 2012 12:44pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34960 |
re the charger, a few members have got solar powered ones from maplins .. ... - .- -.
23rd Sep 2012 12:47pm |
Without running out to the car to grab the manual, which ciggie socket is still live when the ignition is switched off and the car locked
23rd Sep 2012 1:04pm |
The one in the boot is always live.
23rd Sep 2012 1:09pm |
Thanks guy's, appreciate it
23rd Sep 2012 1:13pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Hi Dave... Read this thread for info on my solar charger. It recommends unplugging it before you start the car incase surges damage the circuitry.
23rd Sep 2012 4:06pm |
Have you had the agm battery fitted and the updates to the system to reduce the max runtime to 17mins?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
23rd Sep 2012 4:57pm |
I was actually joking about the solar powered parcel shelf but I see you have actually done it...!
23rd Sep 2012 9:14pm |
Oooo, good question, didn't know about that, was there a recall for it or was it just a bulletin 2011 Range Rover Vogue 4.4 TDV8, Mine........ALL mine. 2012 Freelander 2 HSE SD4 - Mrs UkDave's new toy 2007 Freelander 2 GS TD4 - gone 2010 Discovery 4 XS - gone 2008 Discovery 3 HSE - gone 2007 Freelander 2 GS TD4 - gone |
23rd Sep 2012 9:30pm |
Interesting, but it looks rather large 2011 Range Rover Vogue 4.4 TDV8, Mine........ALL mine. 2012 Freelander 2 HSE SD4 - Mrs UkDave's new toy 2007 Freelander 2 GS TD4 - gone 2010 Discovery 4 XS - gone 2008 Discovery 3 HSE - gone 2007 Freelander 2 GS TD4 - gone |
23rd Sep 2012 9:32pm |
Ask your dealer as there was a long drawn out fight for people to get it fixed last year and they just gave up and fitted a better battery and reduced the run time. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
24th Sep 2012 9:06am |
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 724 |
Your vehicle should have an AGM gel battery fitted, pop the hood and take a look it should be marked AGM. There was also an associated software update to go with the battery but it depends on when yours left the factory. I had one of the first 2011's to leave the factory (Jan 2011 build) and that’s when the low battery messages started appearing. I can't remember exactly when they started to fit AGM's as standard from the factory but I think it was from around June 11. Mine was swapped as part of a recall and has been fine since the battery swap
24th Sep 2012 9:50am |
Just checked tha battery, it's a VARTA that's fitted so it looks like the original battery is still on there.
24th Sep 2012 12:40pm |
