Home > Technical (L322) > Water in spare wheel well |
What colour is the water? I only ask because my compresor failed last month after playing up for a couple of months and I had brown/orangy water in the spair well which I suspect was being blown out of the acumulator tank.
1st Jan 2010 4:26pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3066 |
Hi Axle, thanks for the speedy reply. The water is browny/purple. I think it may well be the compressor but it shouldn't have any water in the compressor should it, as it is a dry system I thought? |
1st Jan 2010 4:30pm |
So did I and like I said I'm in no place to ask the stealers any questons right now, all I know at the moment is that it's fixed but it took the best part of a month to marry all the parts up because of Catapilers fowl up. 2008 MY Supercharged
1st Jan 2010 4:37pm |
Just taken out the spare tyre and the underneath downside is covered in a slimy brown oily gunk. hopefully this will not degrade the spare as it is brand new! looks like something may have come out of the compressor. However I can't get the 3 retaining bolts off to look inside. They just keep turning round. Any tips for getting them out chaps? |
1st Jan 2010 5:27pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6355 |
Have you noticed if the rear wiper washer is not working as well as it should?
1st Jan 2010 6:02pm |
Hi RR. Funnily enough my rear wash does not work, although the wiper does. Stealer said it needed a new pump.....probably! I think this may be leaking and causing the compressor to stop working/short out. thanks for the info.
2nd Jan 2010 10:01am |
I would suggest opening the rear tailgate and remove the top centre plastic trim. You just have to be brave and pull it straight out. If the inside is caked in the brown liquid marks you know that it's leaking.
2nd Jan 2010 7:09pm |
RRUK, you are a diamond! If I had a bit more money I would buy your TD6 (but am saving for a TDV8 ideally!)
3rd Jan 2010 12:16pm |
No problem, always like helping out.
3rd Jan 2010 5:39pm |
