![]() | Home > General > Rear Wiper on FFRR - Rubbish |
| Vogue Member Since: 31 Jan 2008 Location: The Highlands Posts: 1734 |
what other options are there for it? If you want a wiper hidden out of sight and a split tail gate, the only option is at the top of the screen. The Sport has a wiper at the bottom and doesn't get goo running down it, but then it looks cheap as the wiper is exposed and not hidden away... |
| RRUK Member Since: 08 Jun 2007 Location: UK Posts: 3294
Another problem with the Sport version is that the widest part of the arc is at the base of the glass, not where the drivers vision is at the top of the glass! IMO, the Sport way is upside down.
| MICK Member Since: 11 Sep 2008 Location: Here Posts: 6588
My rear wiper is S |
might be better with a stronger spring so there's more blade pressure against the screen perhaps? THE INVENTOR OF THE TERM "FULL-FAT RANGE ROVER" :
Either that or a new FFRR |
| nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 1402
You're not Hawaii yet. |
| Dolphinboy Member Since: 07 Dec 2009 Location: SW Posts: 287
I get great wiping by the blade but the water spray bit doesn't work. Any ideas why not? the water pump for the front works fine. does the rear run off the same pump or does it have its own? (I have looked at the schematic but can't find a pump for the rear) |
sorry, meant to add,...... have had the back cover off adn inspected it and there is no leak. Everything seems normal. |
If its not leaking, then the jets could be blocked. Try a sewing needle inside them. Note, the rear nozzles do not rotate, they are fixed so don't try and force them.
| ukrangie Member Since: 20 Jun 2009 Location: London Posts: 486
I like the way the rear wiper works. I like that it catches the spray and spreads the washing fluid across the screen.
| The doc Member Since: 25 Mar 2007 Location: In car hell :-( Posts: 425
I love my rear wiper |
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 3755
The no return valve has failed in mine, which means I need to press it twice before I get spray, not exactly the end of the world, but it works fine.
| SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 845 |
| speedymarktd6 Member Since: 20 Nov 2008 Location: worcestershire saurcy Posts: 543
| All times are GMT |
