Home > Technical (L322) > wouldnt go in gear and hello Forum |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 725 |
Flush the gearbox and replace the oil would be my initial thoughts.
20th Jan 2010 2:03pm |
kb5 Member Since: 20 Jan 2010 Location: currently in The Sudan, dont ask Posts: 63 |
Do you think this would resolve the issue as I am wondering could it be a torque converter problem I would prefer for it to be just a flush and oil change as I am sure that would be the cheaper fix... |
20th Jan 2010 4:54pm |
jayzee Member Since: 14 Oct 2009 Location: UK Posts: 342 |
I'm not sure what I have is any way related to your problem...
23rd Jan 2010 4:42pm |
Quote edited out by Mod:
24th Jan 2010 7:30am |
Good luck, and hope it is a trivial and inexpensive fix for you.
24th Jan 2010 11:57am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6355 |
These may help when talking to a dealer?
24th Jan 2010 12:23pm |
Oh if only there were a dealer in this country .... Update on post today again my car would not go into gear after I had just driven it. After trying to get it back into gear I returned it back to P there was a kind of grinding clicking noise (sounded similar to putting something on a fan blade). I switched the car off on etc but this was no help, the low range light on dash came on I put the gear shift in N and tried to change range mode but couldn't. I finally got a couple of people to push the car forward which for some unknown reason sorted out the getting it into drive but the low range light stayed on. |
25th Jan 2010 7:47am |
Does it make any difference if you select Neutral and switch it between Low and High range a few times? Discovery 4 HSE
25th Jan 2010 10:23am |
No selected N a few times and tried to get it out of low range but it wouldn't It also wouldn't go into gear and as I said when I put it into P it made this noise of plastic on fan blades? any thoughts ? |
25th Jan 2010 10:51am |
I'm out of ideas I'm afraid, your best bet may be to call a specialist or a dealer service dept. Have you got any numbers/ a copy of LRO for example? Discovery 4 HSE
25th Jan 2010 2:28pm |
I am sure I'll find some thanks for the advise.. So far ... |
25th Jan 2010 3:15pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
on the td6 trans if the oil is low in the transfer box the high/ low range wont work as it relies on oil to make the pump select high or low if no oil it stays in neutral in yhe transfer box , get down the dealer get a litre of transfer oil and top it up its blind folded hand tied behind your back easy
25th Jan 2010 6:51pm |
ZF Auto Drain plug from Rave Workshop Manual:
25th Jan 2010 7:10pm |
i believe thats the main gearbox would you be able to post pics of the transferbox onto no6 Range Rover
25th Jan 2010 7:13pm |
