![]() | Home > Technical (L322) > Won't start - Immobiliser problems ? |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 746 ![]() ![]() |
What's made you change your mind? |
Yes - one of the big Bosch ones from Euro Car Parts |
Bob the B Member Since: 10 Jun 2011 Location: Newcastle upon Tyne Posts: 163 ![]() ![]() ![]() |
Ive had the same problem a couple of times.
Maybe before you take the vaseline out and go to the stealers, take the immo ECU connector out and give it a good clean (contact cleaner) and see if that makes a difference. Maybe it is just a bad contact in there considering the age of the car. MY 2010 5.0 SC Galway green and sand interior!!
I'll buy some today, and give it a go |
Lighty Member Since: 15 Oct 2012 Location: Manchester Posts: 7 ![]() |
Hi mate, can you describe exactly what happens when you turn the key? I presume you hear the click as the key goes in the slot, then do you have all the lights on the dash lit? DO they all stay lit or do the ones that should go out go out? Where are you based? Im in Manchester with All-Comms if needed? Just describe exactly what happens when you go through the start up sequence. If you want to talk on the phone mate drop me a PM
RF10 Member Since: 14 Oct 2012 Location: Embrach Posts: 14 ![]() ![]() ![]() |
I have just experienced similar. When turning the key all I got was a buzz/whirr/bleep sound and starter motor didn't even try to turn. Battery and starter motor all good.
Didn't think of that but RF10 has a point there, could be the starter switch itself. Again use contact cleaner spray on it.
mattyboy Member Since: 14 Feb 2012 Location: Colchester Essex Posts: 28 ![]() ![]() ![]() |
Have you tried it in Neutral rather than Park? |
Got there in the end |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35862 ![]() ![]() |
whats that then? ... - .- -.
Looks like a starter switch to me........... MY 2010 5.0 SC Galway green and sand interior!!
Ignition switch |
trainmanone Member Since: 26 Jul 2012 Location: stockport Posts: 201 ![]() ![]() ![]() |
that was the same problem i had a few months back,gave it a good soak in contact cleaner,problem solved have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
