Home > Technical (L322) > Juddering and rough running on cold start
Deasy
United Kingdom 2002 Range Rover Vogue 4.4 V8 Java Black
Hi all, i know there is a thread going about juddering, but i think this is differant.
So the juddering has now come back again when on petrol, runs fine on LPG though.
And the engine light has come on too, so plugged it in and its saying its an p0202 injector malfunction on cylinder 2
and also a p0302, a cylinder misfire detected
Back to the garage then tomorrow quoted £198 inc materials, labour and VAT
Do I just a new injector?? Or can I flush it mabee? Or run a tank of bp ultimate petrol through it??
Also just to add its only really when cold tht it's the biggest issue, and the warning light has now gone off and driving fine again. It seems to be intermittent
Any help would be greatly appreciated Smile thanking you! Thumbs Up Bow down
Post #150010 6th Nov 2012 7:00pm
Deasy
Please can someone shed some light on this for me Sad having abit of a stress!
So the intermittent fault now seems more perminant, I know I have two fault codes, one of which is is an injector malfunction and the other is a cylinder misfire on the same injector
It only seems to do it on petrol, so I'm guessing that it's a new injector? Is this an easy enough job for me to do myself?
Or is ther anything else I can check?
But iv just been out in it (20min journey) and it misfired all the way, and also it would change to LPG, I'm guessing it won't change over if ther is a current fault??
I now also have a misfire on cylinder 6 and 7 aswell, but they are pending faults in the last driving cycle, not stored faults?
Please can someone give me a little info? Or help on what I need to check or look at?
Cheers Bow down
Post #151891 18th Nov 2012 6:57pm
crookedm
2007 Range Rover Vogue SE TDV8 Java Black
Hi I had a juddering on my car whizzed it into a dealer and they say its a faulty egr valve. May not help you as you say petrol and mines a diesel.
Post #151897 18th Nov 2012 7:14pm
mjdronfield
Coil packs ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #151899 18th Nov 2012 7:19pm
Deasy
Lol not got an egr,
I'm hoping it's nothing too major, just spent another £300 to get it through the mot, 2 tie rod ends and a rack end
Missis is 39 weeks and due to drop next Saturday, so not really got the money at the moment to keep shelling out on it
Going to need to get too the hospital soon and carnt be worrying about it lol Big Cry
Post #151902 18th Nov 2012 7:22pm
Deasy
How do I check the coil packs mark?
Post #151903 18th Nov 2012 7:23pm
Deasy
Surely if the coil pack was faulty then if would be an issue on LPG aswell?
Post #151907 18th Nov 2012 7:36pm
Deasy
I assume any wiring in the engine shouldn't be twisted together? Lol
I might start with connections then Censored
Post #151908 18th Nov 2012 8:21pm
That wiring is a right mess and bare wire showing too
Post #151909 18th Nov 2012 8:37pm
Deasy
Yep I guessed that, I'm an electrician even though automotive is different to industrial and domestic, I hate people badging stuff, and thers no excuse for untidy half done jobs another than laziness Sad
Post #151911 18th Nov 2012 8:42pm
mjdronfield
not an expert on this, but i'm pretty sure you can swap the coil packs around and see if the fault moves with the pack or stays with the cylinder.....
bit of a long shot i know 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #151912 18th Nov 2012 8:43pm
Looks like there are a few wires there that have been tampered with and joined together with black tape Big Cry
Post #151913 18th Nov 2012 8:52pm
Deasy
@47p2
I'm assuming it's where thy have tapped into the injector feed to get the sequence for the LPG injectors?
Which could very much be why I'm getting an injector fault if the wiring looks like this! Big Cry PITA!
I'm guessing I should do a full battery disconnection before reterminating any of the wiring?
Post #151914 18th Nov 2012 8:55pm
ebajema
If the problem is only on petrol and not on LPG it is most likely the petrol fuel system. With the injector malfunction flaring up, I would say to start with the fuel injectors and not the coil packs.
First run it with injector cleaner for a bit and see if that clears it.
Also if you know which injector is the culprit, remove it, clean it thoroughly and put it back. Have a look inside as well when you have removed it to see if there is anything the fuel line that could cause an issue.
Also clean and check the electrical connector to the injector ! MY 2010 5.0 SC Galway green and sand interior!!
Post #152002 19th Nov 2012 12:07pm
mjdronfield
The coil packs were a bit of a long shot, but can also show intermittent failure..........so if you've tried everything else.......
I am sure there are places that can check your injectors, and even clean them, though poss a good dose of injector cleaner may help. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #152064 19th Nov 2012 4:03pm
