Home > Maintenance & Mods (L322) > TD6 Ecotuning gearbox |
chinkoa Member Since: 17 Jan 2014 Location: West Yorkshire Posts: 34 |
No he couldn't, I agree. I will contact you Megawatt in 2/3 weeks to sort something out. |
8th Jun 2014 10:56am |
clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 181 |
anyone still using the ecotuning? comments on the new version?
4th May 2015 9:03pm |
jak480 Member Since: 06 Dec 2013 Location: Degernes Posts: 44 |
Hi I use ecotuning for over a year now here in Norway and for me it is working because the speeds here are mostly 80 km/hour this means that the gearbox is in a shifting range before the tuning it would kick down as soon as you touched the accelerator or encounter a small hill. The downside is that the motorvibrations are now more noticeable.
5th May 2015 4:09am |
Balki Member Since: 13 Nov 2014 Location: Tasmania Posts: 35 |
i bought one a couple of months ago and installed it, very easy to do you only have to graft in one extra wire that comes out of the new ecu, i also had my gearbox full rebuilt and modified with better clutchs and a bigger torque convertor lock up clutch, im not sure about the ecu as yet, it does some strange shifting and doesnt seem to lock up consistently at the same speeds etc, i would like the tc to lock up at 50 kph but it doesnt till 70kph, can you update the software to the lastest version yourself or does it have to be sent back, and how can i checkk what version it is.
5th May 2015 7:33am |
7spoke Member Since: 23 Jun 2013 Location: North Yorks. Posts: 7 |
I actually bought one over a year ago for the missus car...and never got around to fitting it! It was the modified one with the extra wire for engine speed. I had the gearbox oil and filter changed around the same time and all seemed well with the box. I'm not sure if I will ever fit it now ....I'm open to offers if anyone is interested....I'm in UK. |
5th May 2015 10:32am |
Tom Paine Member Since: 11 May 2015 Location: Townsville Posts: 47 |
Balki,
13th Jul 2015 11:35am |
thegamekeeper Member Since: 12 Nov 2015 Location: sunderland Posts: 71 |
HI sorry to bother you but do you know if these ecu are still available. if so where from. hows yours goin now Current. FFRR Vogue. TD6 Java black. 2009 Mini Cooper JCW in Black Gone. 2006 Discovery 3 2008 Nissan Navarad40 Td5. Discovery 300 tdi Defender 200 tdi Defender 3 more Defenders 2 x saphire cosworths Various Mk1 & 2 rs Escorts (when i was young and mad) |
6th Feb 2016 7:03pm |
arron Member Since: 21 Sep 2010 Location: lincolnshire Posts: 123 |
hello, the ecu upgrade is still done as i bought it just a couple of months ago. it a nice easy upgrade, heres the link.
7th Feb 2016 11:10pm |
what sort of difference has it made to gear changes. is it any better Current. FFRR Vogue. TD6 Java black.
9th Feb 2016 4:59am |
the gear changes are the same as before to be honest, the only difference is the torque converter locks up a lot earlier (35-40mph) and you can accelerate with out the engine reving alot a not seeming to do a lot, now the car picks up speed alongside the engine, the only thing i will say is sometimes it seems to hold the torque lock up / gear a bit too long when shutting down and can cause a judder, it is simple to drive around once you have experienced it a couple of times though, over all it is definitely worth the upgrade. |
14th Feb 2016 12:03am |
Ollie7195 Member Since: 11 Dec 2016 Location: Somerset Posts: 74 |
Hi everyone! been looking at doing this on my TD6, is the guy still going as I couldn't get the website link to work? I notice when I'm driving if I get above 35 mph and take my foot off the throttle the revs drop right down then if i accelerate gently they go up with the speed as though the t/c has locked is this standard for a normal TD6? (if i accelerate too much it drops down a gear and turns back into a rubber band) or is this "early" lock up when the t/c slips by 3% until it reaches above 50?
17th Jan 2017 6:01pm |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 |
I have been sorting out my boxes of Range Rover spares and came across the Ecotuning box still with instructions.
24th Mar 2017 11:44pm |
Nismotec Member Since: 27 Apr 2019 Location: Dorset Posts: 52 |
I dont suppose this is still available? An old thread I know... or where I can get my ecu modified? |
17th Dec 2019 8:25am |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
Maybe you should change your handle to "!Dr Emmit Brown" 2003 Range Rover Vogue TD6 |
17th Dec 2019 9:59am |
