![]() | Home > Maintenance & Mods (L322) > Finding a template. |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 ![]() ![]() |
It's a long story that I won't bore you with but I need to remove the VOGUE SE badge from the rear of my RR and then clean up the adhesive and re mount the letters in the correct place on the rear boot lid. My problem is I do not have a template for this job and can find none on line. Does anyone have an old one I could purchase or the knowledge how to find one on line.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35831 ![]() ![]() |
before you remove the letters, make your own template and then use that when you reapply.... ... - .- -.
thought that might be the reason .. Craigs idea is one way to go unless someone here will measure up for you and post the results... ... - .- -.
Where in Manc are you Pfazz?
If you buy them new from Dan @ Duckworths, they come with a template ready to stick on...
