Home > Wheels & Tyres > Tyres 285 35 22 |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
I have some Atturo, review here for what it's worth. |
28th Nov 2012 6:06pm |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 908 |
Are the Toyos 106 weight rating upto the FFRR then? What is the weight rating needed for the rangerover? I know a few over on the D3 forum have had trouble with 106 rated tyres on the d3 hence why i went for the 112 rated desert hawks. Am i being over cautious? Paul
28th Nov 2012 6:32pm |
So 106 or above are fine for a FFRR then? must be loads lighter than a D3 . At least that gives more options for tyres when i get my 22s Paul
28th Nov 2012 6:49pm |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
I'm not sure, but I thought RR wheels were rated to 1050, so I'd assume you'd want tyres to match. If you corner hard in a RR then you tend to load up the front tyre you're turning on, which would put quite a bit of weight on it ...
28th Nov 2012 7:26pm |
Thats what i thought. Is i possible to find out the recomended weight rating. Speed rating less of an issue for me and my TD6 Paul
28th Nov 2012 7:30pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Comes with 111 as standard. Well, my td6 did. Previously..
28th Nov 2012 7:33pm |
28th Nov 2012 8:11pm |
MMM the plot thickens . Think i will stick to the desert hawks, at least then there wont be any issues with insurance if the worst happens Paul
28th Nov 2012 10:09pm |
