![]() | Home > Maintenance & Mods (L322) > Rear headlining drooping |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
Never heard of this problem on a FFRR. Maybe it has been causes by a previous owner/vendor steam cleaning |
| JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 269
Relatively simple fix actually. I took a closer look and found the D-pillar trim wasn't clipped on properly (not sure if it ever was as one of the plastic fixings was bent). I straightened the fixing, reattached the trim and it seems to have solved it. |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
There are clips, fixed to the roof, that the headlining clips onto. Maybe one of these has come away. I know because the one in the centre has done this on mine (following install by previous owner of wiring for wireless headsets). Never got round to fixing it. .
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
As above, the headlining next to the rear pillar is held in place by the rear pillar trim. |
| dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457
Same as Joe90 for mine.
I may need a couple of those clips in that case. Do you have a part number please?
I'm at work at the moment, but 99% sure I still have the invoice. I will try and find part number when I get in tonight. |
| All times are GMT |
