Home > LPG > Noisy Pump
Paulhh
Scotland 2002 Range Rover Vogue 4.4 V8 Epsom Green
Noisy Pump
Hi
I'm new to Range Rover Ownership but loving it all the same.
My LPG "pump" that sits next to the LPG tank in the spare wheel space seems incredibly noisy. Is this normal? I didn't expect to hear it running when in the car.
Paul
Post #159466 23rd Dec 2012 10:13am
alz4321
2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Pump ? Mine doesn't have an lpg pump. The only pump in the wheel well on mine is the compressor for the air suspension.
Post #159469 23rd Dec 2012 10:24am
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
It is the EAS compressor, mine is noisey as well, could be its reverberating on something where its been moved from the spare wheel well. LPG systems wont have a pump they just work off pressure in the tank. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #159486 23rd Dec 2012 11:36am
Paulhh
Thanks for that. Must be the suspension pump. Maybe should be mounted on rubber?
Post #159494 23rd Dec 2012 12:04pm
oliver9627
United Kingdom 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
It will be the air suspension pump. I am on LPG and mine has been moved. I can hear my pump very clearly when working. Gone:
Golf GT TDI 150- Still got.
BMW 325TD
Range Rover Classic
Defender 90
Post #159587 23rd Dec 2012 6:33pm
Tallsaj
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Noisy Pump
Hi I have 2005 55 plate sc vogue had LPG fitted but the pump making a lot of noise, it's just sitying above the LPG rang at the mo with bubble wrap and it's not in it's toitoise case??
Post #205429 23rd Aug 2013 11:40pm
Tallsaj
Noisy pump
Hi I am new to the forum. Recently had my range converted to LPG its a Brc system my pump is noisy it's has twin tanks its sitting just above the LPG tank. It's still noisy any one found a good place for it no noise or vibrating??
Post #205431 24th Aug 2013 12:00am
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
most good conversions place the suspension compressor in the Offside cubbyhole and there is a special mount made by one of the larger manufacturers expressly for this purpose. with a bit of sound attenuation it's not too bad - and it only goes off if you change height
Post #205435 24th Aug 2013 12:32am
