Home > Technical (L322) > BIG issue: locked out of the car [SOLVED]
Ibartsimp
France 2008 Range Rover Vogue TDV8 Buckingham Blue
Wow, I think I now have a BIG issue. The battery went down during the night to the point where I can't now open the doors with the remote control. Here comes the BIG issue, the car is locked and the driver's door got a problem yesterday that predvents me from opening it mechanically from the outside.
The bonnet is closed, everything is closed...
How can I do?
(reg the battery issue, see here... http://www.fullfatrr.com/forum/post163961.html )
Post #163985 12th Jan 2013 3:05pm
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
Do you have an auxiliary trailer socket? Might be able to charge the battery through that
Post #163988 12th Jan 2013 3:21pm
Ibartsimp
nope Sad
Post #163989 12th Jan 2013 3:26pm
mrd1990
maybe this: http://www.rangerovers.net/forum/6-range-r...ttery.html
Post #163990 12th Jan 2013 3:29pm
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
If you remove the belly pan under the engine, the alternator plug is accessable. So surely you could charge the battery through thy plug. You would just need to identify the pin out of the plug to locate 12v and ground. MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #163991 12th Jan 2013 3:30pm
You can either connect a spare battery or battery charger to a white tow socket as above, or you can connect a spare battery or battery charger by connecting to the red cable starter connection and an earth point on the car. You need to lie under the car to do this.
Either way will allow you to open the door.
I'm told it is also possible to remove a rear number-plate light and connect a spare battery or battery charger to the lamp connections.
Post #163992 12th Jan 2013 3:31pm
Ibartsimp
Ok, so relieving, thanks a lot, you guys are fast and accurate!
I'll try that with a battery charger when it stops raining...
edit: for accessibility reasons, I'll be using a spare battery + cables.
Post #163998 12th Jan 2013 3:46pm
I had an RAC jump start our Motorhome by Negative to chassis & Positive direct to the Starter Motor. Not sure if this can be done on a RR.
Post #164013 12th Jan 2013 4:39pm
Ibartsimp
Managed to get in the car with the blinker method Smile
However it won't start. I have my defender giving it power at about 2000rpms but the key doesn't unlock the car Sad
Post #164038 12th Jan 2013 5:38pm
You will need to charge the battery from now until tomorrow morning to get a reasonable charge into the battery, particularly as current is draining away at the same time. Be patient. Smile
Post #164039 12th Jan 2013 5:51pm
mrd1990
Those defenders really are under-powered Laughing
Did the key unlock the car when you connected the battery to the blinker? might be a bad connection between the defender and range rover.
Post #164115 12th Jan 2013 10:24pm
Ibartsimp
yes the doors were unlocked by the remote key.
Post #164145 13th Jan 2013 12:50am
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
My driver's door lock wasn't working with the key in the barrel and I was worried about the very same thing; battery going flat and how I would get in. I'm glad you solved it.
The fact that LR have saved costs by fitting ONE lock is pretty outrageous really. My advice to anyone here is to periodally check that you can unlock the driver's door with your key! 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #164398 13th Jan 2013 8:27pm
Ibartsimp
maybe security reasons ?
I've just discovered that my blinker isn't operating anymore, maybe I rewired unproperly...
Post #164415 13th Jan 2013 9:14pm
SKOT
Security? Nah - Cost cutting. It's much much cheaper to put a blanking plate than it is a lock..... Evil or Very Mad 2006 4.2 SC
Post #164427 13th Jan 2013 9:46pm
