Home > Maintenance & Mods (L322) > Flat battery issues |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3654 |
I had a thought
10th Feb 2013 11:58am |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 |
I had heard that it checks its level every Xmins. However i was subsequently told that it does go into a 'sleep' mode.
10th Feb 2013 6:29pm |
It will re check every now and again
10th Feb 2013 6:33pm |
Leaving on bump stops? Is that the same as leaving in access mode or is there something new for me to discover? Geoff |
11th Feb 2013 10:41am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34945 |
bump stops are slightly lower than access...normally goes to this if you've had it jacked up [repairs etc] and then let it down.. ... - .- -.
11th Feb 2013 10:51am |
After I have jacked it up, it stays there, higher than off road, until I start driving it.
11th Feb 2013 5:33pm |
or take a booster pack/second battery.
11th Feb 2013 7:10pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
I would disconnect the battery -ve terminal when you park the car and accept you have to open it with the key before re-connecting battery.
11th Feb 2013 7:24pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7791 |
Solar charger ? |
11th Feb 2013 7:29pm |
Saint.v8 Member Since: 13 Jun 2012 Location: UK< Surrey - Near the Middle Close to Some Green Bits Posts: 94 |
Thought relevel when parked up was: after last door is closed, then every 6 hours...
11th Feb 2013 11:13pm |
No it will use up what's in the reserve then start the balancing act bleeding the system to equalise it until its drained. The control valve isn't too powerful but its constant kick in and out will have that affect on any battery FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
11th Feb 2013 11:25pm |
12th Feb 2013 9:32am |
I think some of the things in those documents have either been changed with updates or were just bs to start with though FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
12th Feb 2013 9:49am |
