Home > General > Starting TDV8 when very cold; anyone have any experience?
Page 1 of 3 123>
inkiboo
Switzerland 2007 Range Rover Vogue SE TDV8 Java Black
So as this photo shows ...
... I'm spending some time in some quite cold places. When I'm at those temperatures, it seems the TDV8 has trouble starting. It will start eventually but I will have to old the key while it tries to turnover and normally on the 4th or 5th time of returning the key it will start.
I've followed the cold start procedure in the manual (as outlined above) but just wondering if anyone else had experience at these temperatures?
Post #13204 15th Feb 2010 2:56pm
dan_uk_1984
Do you set the pre-heater to come on 20 mins before you intend to start?
Post #13208 15th Feb 2010 3:19pm
inkiboo
I didn't think the TDV8 had a pre-heater? If it does, I have no idea how to activate it!
Post #13212 15th Feb 2010 3:29pm
It has a pre-heater and a hand book Thumbs Up 2008 MY Supercharged
Post #13213 15th Feb 2010 3:35pm
inkiboo
Unless I read it wrong, it referenced a pre heater and a remote control and mentioned being fitted to certain models. I therefore assumed my model was not one of them. I may even go down to the car park now to check.
Post #13215 15th Feb 2010 3:36pm
dan_uk_1984
The remote is optional, or the previous owner may have just lost it.
ALL diesels have the aux fuel burning heater installed, but only some have the remote function. I believe all can be programmed to start independently.
The only model this was not standard fit on was the Petrol's although it was an option.
Dan
Post #13219 15th Feb 2010 4:14pm
inkiboo
Dan
Interesting; will ask at my local dealer. I 100% don't have the options in Settings to set times for the heater to come on.
Post #13221 15th Feb 2010 4:18pm
Vogue
If its a Vogue model upwards, you should have had the remote with the car.
We have had very low negative temperatures up here and they have started 1st time everytime even without the preheater. The only problems we have is when a battery is goosed.
Post #13222 15th Feb 2010 4:18pm
dan_uk_1984
I don't know how the menu is laid out on yours, but on mine it's called "aux ventilation" on the main page, but being petrol there is no heater. If the heater is there I think its called Aux Heating?
I know Gaz has the TDV8 so maybe he'll post soon.
Post #13224 15th Feb 2010 4:23pm
inkiboo
It's a 2007 TDV8. Weirdly, it only has issues when parked in the underground car park; if we leave it outside overnight it is fine starting.
Post #13227 15th Feb 2010 4:48pm
The Pre heater or auxiliary fuel burner has NO beneficial effect on cold starting. If you use the pre heater to warm the cabin, in very cold weather it is most likely going to drain the battery and prevent the car starting.
To start the car in cold climates the manual states it may take a few turns, and you should ensure all electrical items are switched off i.e. Auto lights, audio, heater etc. Crank it for up to 10 seconds. Discovery 4 HSE
Post #13228 15th Feb 2010 5:10pm
dan_uk_1984
The pre heater circulates hot water around the engine block - how can this not be beneficial?
FBH System
The system consists of a FBH unit, a FBH fuel pump and a changeover valve. On vehicles with the remote operation feature, the system also includes a FBH receiver and a remote handset.
Fuel for the FBH system is taken from the vehicle fuel tank, through a line attached to the fuel tank's fuel pump unit, and supplied via the FBH fuel pump to the FBH unit. In the FBH unit, the fuel delivered by the FBH fuel pump is burned and the resultant heat output is used to heat the engine coolant. The changeover valve isolates the heater coolant circuit from the engine coolant circuit
Post #13231 15th Feb 2010 5:26pm
This is what RAVE tells me:
Changeover Valve
The changeover valve is a normally open solenoid valve installed between the supply and return sides of the heatercoolant circuit. The changeover valve is located in the engine compartment on the engine bulkhead. When de-energised, the changeover valve connects the heater coolant circuit to the engine coolant circuit. When energised, the changeover valve isolates the heater coolant circuit from the engine coolant circuit.
Doesn't this mean that if the FBH is activated (energised) the coolant flow is restricted from the engine, thereby keeping the heat to itself effectively so it can concentrate on warming the cabin, and not the engine. I have never ready anything anywhere that has stated or intimated that the FBH is there to pre-warm the engine to make it easier to start, I've only seen that it is there purely for comfort of the cabin area on a cold morning.
I am happy to be corrected BTW, this is not an argument! Thumbs Up Discovery 4 HSE
Post #13232 15th Feb 2010 5:57pm
JMC
RRUK is correct. The FBH in the TDV8 FFRR is a 'Cabin Pre-Heater'. It does NOT warm the engine I'm afraid. Big Cry
Cold temperatures affect a battery at the best of times. Using this FBH function for 30 mins to warm the cabin will only run the fan and hence drain the battery further.
Best advice is to invest in a decent battery charger and ensure the battery has peak capacity to cope with regular cold starts. Thumbs Up The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #13233 15th Feb 2010 6:11pm
dan_uk_1984
As above, Rave states "The changeover valve isolates the heater coolant circuit from the engine coolant" and "the resultant heat output is used to heat the engine coolant"
We cant both be right, and both statements cant be correct surely? I got mine from the desc' and operation section.
Dan
Post #13237 15th Feb 2010 7:16pm
Page 1 of 3 123>
