Home > Technical (L322) > Calling RRPhil
Page 4 of 7 <1234567>
RRPhil
Eugene,
I’ve had a quotation back from JPAT now. Prices are as follows :
Intermediate Sheet = £34.60
4-off Jump Tubes = £6.92
Oil Pump Bridge Seal = £3.61
Next day delivery within the UK = £12.90 (fixed price for all JPAT deliveries)
I enquired about the MV1 damper (a.k.a. delay accumulator valve) and JPAT supplied the cost for the Sonnax Zip Kit for the 6HP26 (see flyer below) which is £93.82. However, the solenoid accumulators in the kit are the six small ones for the yellow and blue cap solenoids. These dampers are there only to prevent oscillation in these proportional pressure control solenoids whereas the much larger one for the MV1 on-off solenoid (with the black cap) is there to control the rate of pressure rise for the E-clutch.
I went back to them and asked again if the individual spools/pistons and springs were available for the valve block and JPAT say that ZF do not supply these, only complete valve blocks.
Obviously the offer is still there if you need my second-hand parts.
Regards,
Phil
Post #185835 30th Apr 2013 7:35pm
ebajema
Hi Phil,
This seems the best option to me to be honest, get the parts from the UK via your supplier and use your second hand parts. Can you PM me your email address so we can arrange things like payment etc.
I really appreciate your help on this.
Kind regards,
Eugene MY 2010 5.0 SC Galway green and sand interior!!
Post #185854 30th Apr 2013 8:40pm
If they can get them to me in the next few days i can ship it altogther as 2 things still waiting to come for you eugene so would make sense to bundle it all up if possible as Phil isnt too far from me i think Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #185946 1st May 2013 12:39pm
ebajema
I would like to get these items quickly (i.e. DHL) and not wait for the air freight (which would take 3 to 4 weeks). MY 2010 5.0 SC Galway green and sand interior!!
Post #185950 1st May 2013 12:43pm
Ahhhh.
Whens the next scheduled one or is it a case of the box being full?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #185955 1st May 2013 12:58pm
ebajema
If it is in before Friday and they have time to pack it into a crate, it goes. Then it takes 2 to 3 weeks on this side to get to me. Unless there is a strike and then it can take a while longer. MY 2010 5.0 SC Galway green and sand interior!!
Post #185984 1st May 2013 2:58pm
I can get the package to you by next friday then if it helps and i can get the lot to me before wednesday Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #185987 1st May 2013 3:03pm
ebajema
Don't worry about the gearbox parts. Once Phil and I sorted things, I want them asap. DHL is days, through the Dutch office is still weeks. MY 2010 5.0 SC Galway green and sand interior!!
Post #185988 1st May 2013 3:06pm
No Worries fella Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #185991 1st May 2013 3:13pm
ebajema
UPDATE :
Monday afternoon my "care-package" from Phil arrived. Everything he promised was there so of course I jumped to it and got everything ready.
Tonight (Tuesday 21 May), I drained the ATF, removed the oilpan/filter unit and removed the Mechatronic. All using Phils ZF teardown post. It worked perfectly, the connector sleeve does not show the corrosion issue but since I have the new one anyway, it will go in soon.
Of course it was a bit of an oil bath but that can be cleaned up (our parking garage has painted concrete floors so should be fine, not like it is the first time it sees some ATF Smile ).
Tomorrow the plan is to split the Mechatronic and replace the parts, while I will give it a good once over and clean out any crap.
A bit of a concern is the magnets (this filter unit has been in for some 20,000 kms at the most). There is some extremely fine blackish dust on it with some courser feeling debris in it. Grain of sand size. I hope that is not the impending doom that the transcooler issue could have caused.
Anyway, I will re-install the Mechatronic to see if that resolves my 3-4 shift problem before worrying about anything else. MY 2010 5.0 SC Galway green and sand interior!!
Post #189704 21st May 2013 10:40pm
ebajema
UPDATE :
Opened up the mechatronic and that seemed to go well. Did have a little scare though, when I noticed these little black plastic balls sitting on the intermediate plate. In hindsight I disassembled it in the wrong orientation. Anway, pretty sure they are all back where they belong.
As predicted by Phil, the seals of the intermediate plate came of at some areas, so very glad I had the new one.
I replaced all the parts that we discussed but unfortunately none of them seem defective (although I can't say anything about the SV1 coil). So I'm hoping it is the SV1 that was acting up.
I did find more of the black debris and cleaned it out as much as possible (quite hard working in a bathroom/shower due to lack of a proper workshop). So here is hoping that this will resolve the problem although not hugely hopeful.
Took quite a while to do all the work (longer than expected), about 4 hrs. (finished after midnight).
Today I'm going to try and put it all back, fill up the gearbox and go for a short test drive.
Will keep you all posted Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #190055 23rd May 2013 9:34am
RRPhil
Ooops, sorry, I should have warned you about the nine 6mm check valves Embarassed
Disappointing that you didn’t find anything obviously wrong. So the damper piston slid up and down its bore okay? Like you say, it’s just possible that the black-cap solenoid will make a difference. Otherwise, back to square one….
Phil
Post #190081 23rd May 2013 12:22pm
ebajema
No worries Phil, looks like I got the little Censored back to where they belong Smile All but one were lying on the plate when I took the "bottom half" off.
Hopefully I know more tonight, if not tomorrow night. MY 2010 5.0 SC Galway green and sand interior!!
Post #190082 23rd May 2013 12:30pm
ebajema
Latest update. The fluid level in the box is probably still a bit on the low side but the first drive revealed that the problem hasn't left the box. So back to square one Evil or Very Mad Evil or Very Mad Evil or Very Mad Evil or Very Mad Evil or Very Mad Big Cry Big Cry Big Cry MY 2010 5.0 SC Galway green and sand interior!!
Post #190471 24th May 2013 10:30pm
Oh Eugene I really feel for you Sad
Are you going to strip down or look for another box? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #190477 24th May 2013 10:45pm
