Home > Technical (L322) > dont need dealer to program new key.
daveo
HI has any one used bmw ews editor, it will write key transponders for bmw style keys fitted to RR upto 05/06
dave V8 facelift Range Rover Autobiography 22" wheels.
Post #181553 6th Apr 2013 6:04pm
daveo
hi,i have done it, i have managed to clone lost keys or add new keys to the range rover with the bmw ignition system, but i think i went over the top and now have 6 keys for the car Laughing V8 facelift Range Rover Autobiography 22" wheels.
Post #181738 7th Apr 2013 7:09pm
barracuda816
United Kingdom 2005 Range Rover Vogue SE Td6 Tonga Green
is it just me or have you replied to your own thread? Whistle Rolling with laughter
Post #181747 7th Apr 2013 8:02pm
Laughing ... - .- -.
Post #181752 7th Apr 2013 8:26pm
comports
Dave's trying to convince himself that having 6 keys is a must...
Think of all those "safe"places you can hide them all incase you loose a set. Shocked Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #181762 7th Apr 2013 9:48pm
daveo
i got a bit carried away with my self, the stealers wanted 250+ after programming and i was ot going to pay that. so the thought of only having one key and if it got lost is not something i wanted to think about.
the worst did happen to my mate while out,he lost his key to his merc and with no key cover his bill was just short of £500 after the recovery plus new key. V8 facelift Range Rover Autobiography 22" wheels.
Post #181768 7th Apr 2013 10:18pm
So what do we need to do this daveo ? Is it cheaper than buying a key from the stealer ? What if I only have one key? .
Post #181771 7th Apr 2013 10:33pm
daveo
you need a unit called EWS Editor, new chip, and a key blank, the hardest part is removing the EWS unit from the car(center consle out) as you need to read this with the new tool, this is the bit where you can do the damage, you need to touch a pin on the board to read, after you get the info from the unit you can start writing a new key,once done then its back to the EWS and you have to write back to it and tell it that a new key is on the system.
i started with a few second hand EWS of ebay to mess around with, i killed the first one within seconds by touching the wrong pin,easy done...the second one was better and i got info out of it but then had trouble with doggy fake chips,can you imagin it, fake Censored transponder chips. like most of this stuff its from china so the after sales support is not up to much,they do try but broken english makes it hard, V8 facelift Range Rover Autobiography 22" wheels.
Post #181772 7th Apr 2013 10:52pm
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
Like many owners I suspect I'd like to freshen up one of my keys which has a pierced case through wear and tear but this doesn't seem like a job for the faint hearted.
Post #181781 8th Apr 2013 6:55am
daveo
not a very hard job at all, what type of key do you have rich V8 facelift Range Rover Autobiography 22" wheels.
Post #181788 8th Apr 2013 7:56am
Rich86
It has arrow to open, large button to close and boot release with red light in the corner. Probably original I would say dave.
Post #182130 10th Apr 2013 8:02am
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
hi daveo i like the sound of this little project Smile i am in the same position with only having 1 key at the moment after my second one died after trying to transfer it to the new shape key. What sort of costs are involved?
Matt
Post #182181 10th Apr 2013 2:08pm
Rich86
Daveo I've replied to your question...
Post #182452 11th Apr 2013 7:57pm
daveo
rich, you can recase your key for around 10 pounds
http://www.ebay.co.uk/itm/LAND-ROVER-3-BUT..._426wt_905
timpsons will cut it for 5 pounds V8 facelift Range Rover Autobiography 22" wheels.
Post #182459 11th Apr 2013 8:15pm
daveo
matt, your key that is locked out can be re coded, i think i have one transponder chip left, i can do youa key FOC but you would need to send me you ews unit V8 facelift Range Rover Autobiography 22" wheels.
Post #182460 11th Apr 2013 8:19pm
