Home > Technical > iBus + Resler Interface + Navcoder
Page 2 of 3 <123>
Tesh
United Kingdom 2004 Range Rover Td6 Vogue Auto Java Black
Dan
Im literally plugging the ibus 3 wire plug (4th is spare) from the intravee into the Resler USB interface and it cant find it
My Resler is the USB not the circuit board type like yours
I have as yet not gone into device manager to set the com ports but will try that tonight
Paul
Post #15715 26th Mar 2010 10:19am
Stebo
2003 Range Rover 4.4 V8 Vogue Auto Giverny Green
Try using a few different usb ports and changing the com number (com6 worked for me for some reason). Also check everything is working - I managed to blow a few fused which didn't help!
Post #15720 26th Mar 2010 11:51am
dan_uk_1984
Tesh wrote:
Dan
Im literally plugging the ibus 3 wire plug (4th is spare) from the intravee into the Resler USB interface and is cant find it
I have as yet gone into device manager to set the com ports but will try that tonight
Paul
Like I said, only connect the iBus data and Earth. Then see how you get on.
D
Post #15721 26th Mar 2010 1:12pm
Tesh
Thanks for the quick replys guy's
Ill get to the bottom of it tonight
Tesh
Post #15728 26th Mar 2010 2:36pm
Tesh
well gents I have tried every which way I can and it doesnt work
I am really peed off with the £60 wasted on this rubbish!!!!
Post #15765 27th Mar 2010 9:16am
dan_uk_1984
A bad workman blames his tools. Sorry, no offence intended. BUT it does work, the fact that you can't get it to work does not make IT rubbish.
There is of course the posibility that the interface is broken. If you plugged the lead from the CD changer strait onto the board then it will be as the 12v and earth are the other way round. Only if you used the end plug and then a ground wire will it work. If you've punted 12v+ around a sensitive circuit then it may be fried.
If you want me to check the board works pm me and I'll send you my address so you can post it to me and I'll check it out for you.
PS, I never got intravee to work in my car, I was using all 3 wires. I bet if I used just the two now it would work. I ended up cussing it and selling it on for a loss! Embarassed
Dan
Post #15769 27th Mar 2010 9:30am
Tesh
Dan
Its the drivers Im having trouble with
I cant get them to install correctly
On the Resler site it states that the USB type needs a permanent live feed
Tesh
Post #15771 27th Mar 2010 9:59am
Tesh
managed to get the drivers installed corrwectly
Its now reading the ibus but cant seem to program the tv or the light warning although it tells me it has been coded and turn ignition off then on to confirm
Any ideas?
Cheers
Paul
Post #15774 27th Mar 2010 11:04am
Tesh
ive noticed with car in drive if i pull the handbrake on one click the tv comes on
Post #15775 27th Mar 2010 11:10am
dan_uk_1984
Did you do a "Read" first? this then sets navcoder up for the options you have, rather than its default options.
In TV, you need to make it look like this:
Post #15776 27th Mar 2010 11:22am
Tesh
yes I read first then ticked the 2 boxes then pressed code
it said coding succesfull, switch ingnition off then on to activate the new settings
Post #15777 27th Mar 2010 11:41am
Tesh
It appears to be programming the car but when you test what ever you have programed it hasnt been successful
Post #15778 27th Mar 2010 12:00pm
jayzee
2006 Range Rover Supercharged Vogue SE Auto Java Black
I think to get to this level of detail, and to be successful, you really need to either go to a dealer, or invest in one of those £1k devices (on ebay).
I have found that most of these cheaper systems purport to be able to communicate and adjust with most systems, but the reality is that they can't - not to that level.
Yer pays yer money, and get what you pay for IMO Big Cry Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD!
Post #15782 27th Mar 2010 2:45pm
Tesh
Success.............................. the TV is enabled Cool Cool
ll I have to do now is sort the "check side light" warning
Tesh
Post #15785 27th Mar 2010 3:10pm
dan_uk_1984
Maybe you're doing it wrong, or maybe you're a dealer in disguise?
There are cheaper options out there, it's a lot more complicated to figure out how to do it yourself though over taking the car to the dealer. But if money is no object then I see your point.
Post #15829 27th Mar 2010 10:57pm
Page 2 of 3 <123>
