Home > Wheels & Tyres > TPMS
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
TPMS
I have just acquired a new set of wheels and it looks like they are fitted with TPMS.
Will the car recognize them or does it need to be told?
Ian
Post #183506 18th Apr 2013 9:34am
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Post 2006 vehicles will recognise new TPMS sensors, but you need to go for a 15mile drive. Not sure about pre 2006. This does assume that the batteries in the TMPS sensores have not gone flat. I think ther may have been a change of sensor around 2010 and I don't think they are compantible with 2006 to 2010 system. I think the 2002 TPMS system uses different sensors to the 2006 onwards. 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #183536 18th Apr 2013 1:17pm
RR2008HSE
The post 2006s will recognize wheels that are turning. I read that the dealer gizmos need to be used to 'introduce' the car to the spare tyre. I don't know whether temporarily installing the spare after the car recognizes the four regular tyres will work, but if you don't have easy/cheap access to the gizmo, it may be worth a shot.
Post #183621 19th Apr 2013 1:15am
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
Put your spare on as a road wheel first, it will/should self-learn all new sensors fitted to an axle on the 2006-2009 system, mine did. Then put your spare back in the boot and put your 'permanent' road wheel back on. Thumbs Up
edit: Just seen your car is 2011, so above may not be applicable Exclamation
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #183626 19th Apr 2013 7:11am
IanV8
Fitted all five wheels yesterday and went for a run but nothing happened.
Tried to select the menu option for changing the pressures but it is not available on the menu.
Longer run today, away for the weekend with the van, so will see what happens.
Ian
Post #183639 19th Apr 2013 8:24am
IanV8
Nothing appeared on the dash at any time so I reckon the car has not detected the wheels.
Did not really want it anyway.
Ian
Post #184004 22nd Apr 2013 9:42am
taskam
Ian, just to clarify, is the TPMS warning light illuminated on the dash? 2007 TDV8 Vogue SE Java Black
Post #184006 22nd Apr 2013 9:48am
TugRR
Is TPMS a nuisance on an already complicated car ?
I'm asking as it may well be (or not !) on my next car . . .
Thumbs Up Where do you go after one of these . . . ?
Post #184022 22nd Apr 2013 11:07am
dave699
If your buying brand new next time, you'll probably find it is.
Recently read something about it being compulsory on all new vehicles in the very near future...
Have a look:
http://www.andrewpage.com/content/6/news/2...ed_to_know
Had it, loved it!
2007 Vogue SE TDV8
Post #184049 22nd Apr 2013 2:44pm
IanV8
No warnings on the dash and no menu option to change the pressure setting.
Ian
Post #184171 23rd Apr 2013 8:22am
taskam
It looks like you have the TPMS disabled. You would have a low pressure warning light if it was enabled and the sensors weren't recognised 2007 TDV8 Vogue SE Java Black
Post #184174 23rd Apr 2013 8:38am
