Home > Technical (L322) > Engine Management Light + engine temp |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 |
Welcome to the forum.
19th May 2013 10:21pm |
Morango Member Since: 19 May 2013 Location: Glasgow Posts: 21 |
Thanks.
19th May 2013 11:09pm |
Oh, and in addition to the above I am now hearing a ...." Tat tat tat..." Or ..." tick tick tick..." As the engine ticks over. If I rev the engine it gets faster the higher the revs go. I definitely did not hear this when I bought the RR. But I'm obviously now listening more intently. I've read various posts now on timing belt tensioners, to oil changes, to "they all make that noise" . It had a service in January at 73K and it now has 76.5 k on the clock.
20th May 2013 12:31am |
The ticking happens on mine as well, I'm not sure if it's the injectors or the ignition packs firing but I don't think it's anything to worry about.
20th May 2013 1:53am |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
I can't help you with the other questions, but I too was surprised with the speed of the warm up. My mechanic said that was due to being an all Aluminium engine. In Canada, it's a very nice 'problem' to have. |
20th May 2013 3:18am |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 |
The ticking sound. Does this come from the cam cover area and does it sound like the fan is hitting something?
20th May 2013 7:02am |
daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201 |
Might be worth checking the pcv pipes for EML
20th May 2013 7:29am |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
The ticking could be a number of things. If it's a light ticking its probably normal. Could be timing chain guides or the vanos system. quite often an oil change for a slightly heavier weight oil can cure it.
20th May 2013 9:02am |
Hi guys,
20th May 2013 9:10am |
Hello everyone,
20th May 2013 7:23pm |
What experience does your local garage have with rangys? Did they check any of the things mentioned here? how are you with using some simple spanners? |
21st May 2013 11:10am |
Hi rob,
21st May 2013 12:05pm |
Sorry
21st May 2013 12:09pm |
I think I'd make the drive down and combine with short break in London just t make a point and as a matter of principle.
21st May 2013 6:43pm |
