Home > Maintenance & Mods (L322) > brakes !!!! |
simonmanx Member Since: 17 Feb 2010 Location: Isle of Man Ballasalla Posts: 157 |
Im ready for new discs and pads all four corners i have seen some on ebay for around £70 an axle but has anyone got them off there or does anyone know of any tried and tested replacement makes of disc or pads??or best place to get them |
21st Mar 2010 4:42pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
mine were boxed as britpart but i got them from mm4x4 onto no6 Range Rover
21st Mar 2010 6:42pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6342 |
I wanted to do the same on my TD6 last year, but I just couldn't get the damned calliper bolts undone, I needed the car on ramps so I could use something long enough to get enough torque on the bolts. I think for simplicity and safety sakes, buy the parts on-line, get a local indy (doesn't have to know RR's) to do the grease monkey work, I think they charged me about £50 to fit the parts.
21st Mar 2010 7:20pm |
alexbartman Member Since: 08 Dec 2009 Location: UK Posts: 43 |
sorry to hijack your thread - but I need to replace the brakes all round on my 2007 TDV8....I am a novice in terms of oily bits (no problem with electrical or interior)...but I am up for the challenge (I think)
22nd Mar 2010 7:52am |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2917 |
I bought mine off eBay as well (autopost) and they're fine. I wish I'd known the hubs were going to rust - I'd have painted them first! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
22nd Mar 2010 5:15pm |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1070 |
I did mine this evening, if you can not figure it out just from looking at it then probably best paying someone competent. All I have to do now is get the check pads light to go out. letters not necessarily in the right order |
7th Apr 2010 7:37pm |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 |
How long do peoples pads and discs last?
7th Apr 2010 7:56pm |
You need to check them, there's no hard and fast rule but if they've never been replaced then its probably worth it. Discovery 4 HSE
7th Apr 2010 8:13pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3682 |
If they are original OEM my LR main-agent reckons on 2 sets of pads to each set of discs. I have had 3 sets in 50k miles on the front of one of my FFRR, mind you they are used to tow and off road use as well - you have done blooming well to get 60k! |
7th Apr 2010 9:22pm |
Yes, I don't use the brakes very often... |
8th Apr 2010 7:39am |
To work out how long your brakes will last, you need to work out your “Brake Application Time” (Seconds, minutes, hours) and the “Brake Pressure” (Light = 1, Med = 2, Heavy 3) multiplier. This is of course assuming you are using OEM spec pads, otherwise you also need to factor in “Friction Material Density” (Soft -1, OEM 1 , Hard 2) Very simply put: (Brake Application Time x Brake Pressure) x Friction Material Density : (X x Y) x W = How long your pads will last. Simples To work out how long the discs will last is much more complicated as you need to factor in pie, rotational distance, heat dissipation, surface adhesion and cast quality. Not so Simples |
8th Apr 2010 8:50am |
in simple terms I think after reading all that, Dan means it depends how much you use them |
8th Apr 2010 9:14am |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
You forgot to factor in the temp and height above sea level |
8th Apr 2010 3:12pm |
