Home > Technical (L322) > Brake pipe corrosion |
Trev18 Member Since: 23 Apr 2013 Location: North Manchester UK Posts: 267 |
Hi - I've had my 55 plate FFRR for a month now and as a precaution I had it independently checked.... and one of the advisories was brake pipes showing signs of rust and corrosion and although showing this not a necessary change required. I will check back with the guy next time in the garage.
6th Jun 2013 11:39am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2598 |
As far as I can remember I used to sell copper brake pipe back in the late 80's ( from a motor factor), didn't sell steel, never heard of this use on modern cars. My brake pipes to the rear were replaced completely last year as they were at the point of failure. Scary thing is, only reason my mechanic had a look as he was replacing the saddle pump beside the fuel tank & had the access panel off. They can't check them for the MOT as they aren't visible there. He kept the old ones to show me and was an eye opener to say the least, best few hundred quid spent! |
6th Jun 2013 12:27pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
My mistake They are indeed steel.
6th Jun 2013 12:32pm |
Monty1 Member Since: 07 Oct 2012 Location: Middlesbrough Posts: 181 |
Probly made from straws, chocolate gearboxes and balloons for suspension bags, |
6th Jun 2013 12:52pm |
dirtyharry Member Since: 23 Oct 2012 Location: Ashby Magna Posts: 242 |
Had an advisory last year and this year on the MOT. Must get round to sorting them, but they're down at number 4 or 5 on the list of things to do! Cheers
6th Jun 2013 1:35pm |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
I also had an advisoy last Aug after MD service - quoted a crazy price to replace them!
6th Jun 2013 3:58pm |
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 220 |
Mine are showing external corrosion and I m currently working out how much if the whole set to replace. Certainly the big long pipes from the back wheels.
6th Jun 2013 5:23pm |
TtheArab Member Since: 26 Apr 2013 Location: Dunblane, Scotland Posts: 89 |
Tee. Where did you get yours done ? I am just down the road in Dunblane. I am waiting for Brembo's and rear calipers back from Porsche calipers then intend to get steel braided hoses into them but sounds as if you had more substantial replacement done ? |
6th Jun 2013 6:02pm |
Steel seems to be the material of choice for oem brakes lines, ive had to have a few sections replaced on various vans etc, not on the ff though yet.
6th Jun 2013 6:57pm |
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 |
I had two brake pipe failures during the last MOT couple of months ago ...one while the mechanic was driving the car to be tested , the other when it was on the brake performance machine
6th Jun 2013 7:26pm |
TtheArab yhm |
6th Jun 2013 9:01pm |
Ta |
6th Jun 2013 9:07pm |
barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213 |
Just a quick note for those looking to change their pipes, make sure they are cupronickel not copper.
6th Jun 2013 9:49pm |
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 |
If your brake pipes start to look bad, get them done now as it could save you money in labour costs.
6th Jun 2013 10:52pm |
