![]() | Home > Technical > Brake pad change void warranty? |
| delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1093
Hi Mike
| RRUK Member Since: 08 Jun 2007 Location: UK Posts: 3294
I had fitted pattern brake parts on the TD6 and they were crap. I ended up swapping to genuines fairly soon afterwards.
| funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 22
Thank you both! Question. The car only has 20k miles on it. Can the front disc's be turned or do they need to be replaced? Thank you! Mike |
| Vogue Member Since: 31 Jan 2008 Location: The Highlands Posts: 1734 |
blimey, 20k miles, what you do drive with your footbrake on |
Best to replace I would suggest. The cost is not that much really (in the UK anyway) and for peace of mind etc. THE INVENTOR OF THE TERM "FULL-FAT RANGE ROVER" :
| Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 142
Can the brake warning light be reset by me having repplaced the pads or is it a proffit oppertunity for the steeler? letters not necessarily in the right order |
| andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 161
the sensor auto resets the warning light so no dealer profit to be had |
| All times are GMT |
