![]() | Home > Technical > Paddle Shift? |
| RRSSS Member Since: 29 Mar 2010 Location: Bahrain Posts: 2
Hi, I've been a fairly light user over on the rrsport forum for the last 3 years or so. Currently own an RRS S'charged, and am somewhat on the way to picking up a 2010 FFRR S'charged. However, couple of questions if anyone could enlighten me?
| RRUK Member Since: 08 Jun 2007 Location: UK Posts: 3294
Hi, Welcome.
Thanks!
| Kilovolt Member Since: 07 Feb 2010 Location: Derbyshire Posts: 105
Had an RRSport 3.0 TDV6 (diesel of course) loaner last week with paddle shift |
| Baben Member Since: 17 Oct 2010 Location: Kyalami Posts: 135
http://www.landrover.com/gl/en/rr/range-rover/explore/hse/
| GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1066
I'd also go for the dark outer trim for the same reason plus I think it looks better. FFRR TD6 HSE
| Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 333
Certainly now standard on 4.4 TDV8s with 8 speed 'box. Unsure about 5.0S/C (it has the old gearbox and selector lever) |
| Gazellio Site Sponsor Member Since: 22 Jan 2010 Location: SITE SPONSOR, Chilterns, UK Posts: 3640
I drove the 4.4 TDV8 for 90 minutes and used the "Paddle Shift" system so I know its there! You can use either paddle to shift up & down (Forward or back) and hold the right paddle in for a second or two to change back to "Drive"..... |
The picture in the e-brochure shows the conventional gear lever AND the paddle switches on the same car Ex: D3 TDV6 SE |
I think that is the case with the new S/C as they kept the stick shift for sportiness - so I am told. |
| kkqd0298 Member Since: 02 Mar 2010 Location: London/Aberdeen Posts: 143
I can confirm that our diesel has the paddle shift and it is fantastic. Cruise along at about 1000rpm, drop down from 8th to 5th and the car charges ahead.
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 3755
I thought that since they've done away with the gearstick and one just has a knob thing ala jag one needs the paddles to be able to manually change either fast on road or delicate off road?
If you look at the eBrochure on the LR site, on page 45 or so, there is a picture of the dash & controls. You can clearly see the paddle shifter AND the gear selector is the conventional stick NOT the dial. It's not clear what vehicle they are showcasing, ie diesel or S/C but it looks like the paddle shift might be able to fit on the S/C
As stated above I am pretty sure they all have paddleshift now but the S/C retained the Stick rather than dial for reasons of sportiness. |
| All times are GMT |
