Home > Technical (L322) > TD6 OBC calibration vs fuel consumption accuracy
goncalo
Portugal 2007 Range Rover Vogue TDV8 Java Black
Hello!
Today i get the real consumption of my 2003 fullfatRR from 2003.
The OBC says the consumption is 8.2 but the real consumption is 9.7!
Maybe it has any chip powerbox and gives bad l/100 consumption... could be the reason?
Or maybe needs some calibration?
i read we can do it in this OBC :
http://www.ideaphile.com/bmw/540-obc.html
i tried but i making something wrong... because i also tried to unlock the hidden menus and i also failed!
http://www.roverupgrades.com/Range_Rover_Hidden_menus.html
Is possible to calibrate the OBC even i have a chip powerbox (i don´t have idea if i have or not) but if i have the car is great because it has a great driving and great consumption!
I love to ear some opinions about this issue!
I really want to have my OBC working accurate! Confused
Thanks,
goncalo Ex-FULLFATTY now downgraded
L494 RRS P400e Dynamic Narvy Black
-------------------------------------- gone
6 | FF-RR 2007 TDV8 Vogue JAVA BLACK
5 | FF-RR 2003 TD6 Vogue Bonatti grey
4 | Ex-RR 2000 P38 automatic
3 | Ex-RR 1994 300tdi classic
2 | Ex-RR 1993 200tdi
1 | Ex-RR 1991 turboD VM engine
Post #197818 6th Jul 2013 4:54pm
goncalo
Hy Again,
Already made it! I try it again all the procedure in : http://www.roverupgrades.com/Range_Rover_Hidden_menus.html
and i unlocked the menus and changed the consumption coefficient in test N.20!
My real consumption was 9,7 and the OBC 8.1. I divides 9,7 for 8,1 and i get 1.2. I changed the KVBR: 1000 (original) to KVBR: 1200. Reseted the OBC consumption1 and now i will see in the next time i fill the tank if teh OBC values are accurate.
At the moment i already see an increase of consumption values with the same driving!
regards,
Post #198466 11th Jul 2013 2:46pm
Thumbs Up I did not know it was possible to recalibrate the OBC. Well done. Previously..
Post #198475 11th Jul 2013 3:46pm
goncalo
Smile and in the end was very easy to do it!
Now i will explore the other hidden menus! Very Happy Ex-FULLFATTY now downgraded
Post #198533 12th Jul 2013 7:43am
goncalo
Today i explored a little more the Hidden menus! IS GREAT!
I found i had 64,5liters on the Tank!
i drive with the instant speed!
AND THE BEST! I drive with INSTANT CONSUMPTION! Very Happy Ex-FULLFATTY now downgraded
Post #199273 17th Jul 2013 6:57pm
SpitfireS
Germany 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
It's an old post but maybe the 2022 knowledge can help.
Is this recalibrating possible on a 2012 4.4 TDV8?
My shown fuel consumption is always 6-7% optimistic.
Cool 2012 4.4TDV8
2000 Honda S2000
Post #646974 31st Oct 2022 4:47pm
GraemeS
Australia
Yes, I reset mine from the original +7% to +5% but it could do with lowering a little further because when towing the van its still too optomistic by a fair margin.
Post #647003 31st Oct 2022 8:02pm
JayGee
It’s programmed to be 7% optimistic but it can be set to 0% in the CCF in the Gap IiD tool which brings in line with real mpg on mine. Also set your tyre size and rolling radius as well if you are running nonstandard size tyres as this will make a difference. 2012 TDV8 Vogue (L322)
Post #647016 31st Oct 2022 9:18pm
