![]() | Home > Technical > Water Pump Failure - Not a nice result.... |
| SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 38
I have recently replaced my water pump. I bought an after market one with an aluminium impeller which IMO is better.
| DeltaC Member Since: 22 Mar 2010 Location: Aberdeenshire Posts: 148
What make is your aftermarket pump and how much was it, if you don't mind me asking?
| elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 700
H'mmmm.... if they are small enough to get through the rad then they are unlikely to have a bird strike effect on the new pump. I suspect they will just be stuck in the gallaries somewhere or at the bottom of the tank.
The two fins that I got back came from behind the pump, in the block which should be where the water comes from to get to the pump. They are half a thumb nail in size but quite hard so if the others have gone in that direction and get picked up by the coolant, they will head to the pump.
The make of the aftermarket pump is First Line, part No.FWP 2181 £72.00 inc vat. Seems to be good quality, time will tell.
| Dolphinboy Member Since: 07 Dec 2009 Location: SW Posts: 287
Stewart, any feedback on your make of pump?
| scarey Member Since: 13 Jul 2010 Location: stan in swindon Posts: 7052
if that's eurocarparts that have quoted you then there's a 30% off code here http://www.fullfatrr.com/forum/topic8057.html .
| duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 711
Pump has done 20000 miles and running fine, would recommend it.
| All times are GMT |
