![]() | Home > Maintenance & Mods (L322) > External emergency bonnet release |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
if you look on our wiki there's a download link for the workshop manual for your range [rave] ... - .- -.
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 ![]() ![]() ![]() |
Ta, will do. |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
If you do come up with a suitable solution, which could be very handy indeed, please don't post it on the open Forum. Regretably not everyone is honest. |
I could not find what I was looking for in the manual. I could not even find how to change my broken bonnet release cable in it. (But I've found how to do it elsewhere on this forum)
there isn't one ,basically for security reasons... ... - .- -.
You dont say which of the three sections has snapped either.
There was a post recently where the owners indie removed the front left inner wheel arch, climbed inside the wheel arch and released the left bonnet latch with tools. Not sure if the right latch can be reached in the same way, from either side.... .
OK peeps, you can install an external bonnet release. I went to Halfords today and bought a small selection of bike brake cable. I was able to push fit the metal blob at the end of one of the brake cables into the remaining space next to the factory fitted cable on the release mechanism. I then threaded the cable through and out of the engine compartment in the vicinity of the front offside wheel arch. I then gave the cable a good pull with a set of pliers and it released the bonnet.
its great when a bit of ingenuity works and you get it sorted.. |
J90 pop round and I'll loosen it off for you if you want as your not far away |
I'll PM you after you collect your new wheels |
Where are you J90? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Having had a look at the bonnet catch mechanisms I agree it would be quite straight forward to fit an emergency external bonnet release.
that makes a lot of sense, job for the weekend me thinks.. |
