Home > My Range Rover > Fixes and new issues |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6356 |
In the grand scheme of things my 'issues' are minor I know, but I am a perfectionist and I want it to be right.
22nd Apr 2010 9:06am |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 |
I also had a similar noise at random speeds between 50-80mph - it was the passenger side roof bar cover (probably not the official name) where the front 5" was not clipped down firmly (new white fixing clip required). |
22nd Apr 2010 11:13am |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Next time it happens, turn *off* the air circulation totally. IF it shuts up then the flaps which open and close to direct fresh air in are hitting a harmonic! My 2006 did this and the dealer explained it to me. It also exlpains the "shwooosh" noise you get when you drive at 70-80mph - that is the system shutting the external intakes off....!
22nd Apr 2010 11:16am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3704 |
I also had this, but it wasn';t any of the above, it was the water washer pipe vibrating at speed due to airflow - usually only over 55mph.
22nd Apr 2010 12:20pm |
