Home > Technical (L322) > Rear Wash/Wipe - One-Way Valve? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6349 |
It all enclosed inside the motor, it's a one piece unit.
23rd Apr 2010 4:07pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2516 |
Thanks - it's definitely not a blocked nozzle as it does eventually work as it should if you keep the stalk pushed for long enough. Will investigate further for hidden leaks.
23rd Apr 2010 4:20pm |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
I'm not getting any water to my rear screen. The motor sounds like its running intermittently when held? Sort of a stop/start. The front is fine.
23rd Apr 2010 4:22pm |
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 |
On my 02 the inline non return valve is adjacent to the motor, when I replaced it a couple of years ago it was about £2.00. If on the later models it is integral to the motor you could cut the tube and use an inline one.
23rd Apr 2010 10:02pm |
tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283 |
On a related note.....
13th Nov 2017 5:40pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
when the wiper starts to go down open the rear gate. it will stop the wiper arm. it will take some practice to get it right. |
13th Nov 2017 5:57pm |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 688 |
Non return valve is situated just to the left of the wiper motor! It is not part of the wiper motor!! 2007 VOGUE SE 3.6 TDV8 |
13th Nov 2017 7:01pm |
Clabs Member Since: 08 Mar 2017 Location: Watford, Herts Posts: 125 |
Great tip Nino - thank you |
13th Nov 2017 10:01pm |
Cheers for the tip!
16th Nov 2017 10:12am |
