Home > Maintenance & Mods (L322) > Theft of Rear Light Units
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Just read the thread re Screws / Bolts and looked at the thread about the theft of rear light units.
http://www.fullfatrr.com/forum/topic303.ht...hts+stolen
I dont know if its still available, but on one of our cars we had the registration number etched into all the windows and front and rear lamps as a deterrent, theory being that if someone nicked the car and tried to change the identity, they would have to change out all the glass as well.
Post #211038 19th Sep 2013 9:58am
ebajema
In the past you could order little sets based on your license plate number with acid. The templates had your license plate number "punched" in little holes. You stuck the template onto the glass and put the acid on the template, leaving a license plate number in dots on the windows.
Here a lot of cars have it done by electric engraver units (looks quite squiggly). I wonder if you should do the VIN number (last 6 digits) i.s.o. license plate number ????
Replacing the hex bolts with torx bolts is a way to make it a lot harder stealing the tail lights. I am waiting for my new tail light, hopefully with two sets of torx bolts to replace my hex bolts Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #211044 19th Sep 2013 10:29am
wealy
United Kingdom 2014 Range Rover Vogue SDV8 Luxor
Its a no brainer - it take 2 minutes and about 50p to change those bolts..........
Post #211109 19th Sep 2013 4:26pm
and the 2 minutes includes a coffee break... ... - .- -.
Post #211142 19th Sep 2013 7:08pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
These are right or wrong?
These are the bolts fitted to the rear lights (that are exposed when you drop down the tailgate)...I assume these are the ones that are referred to in this thread.
Do I need to change mine?....I know were avoiding giving the "modus operandi" openly in case ne'er do wells are reading, so if anybody can tell me how they actually do it by PM, i'd appreciate that.
Cheers.
Paul
Post #241970 11th Feb 2014 5:01pm
your bolts are the newer improved versions...
Post #241972 11th Feb 2014 5:13pm
i've pm'd you Paul..
Post #241973 11th Feb 2014 5:16pm
paulmoran2
Cheers Stan.. Thumbs Up
Message received.I thought that might be the way they stole them.
Glad I have the right bolts fitted, but just in case, I gave them an extra turn with the socket set anyway.
P.
Post #241974 11th Feb 2014 5:22pm
ahh, be careful with the tightening as they go into plastic lugs which can snap..
Post #241976 11th Feb 2014 5:25pm
paulmoran2
I have a delicate touch I'm told
But that's a different thread starter I think Razz
Post #241980 11th Feb 2014 5:31pm
Laughing Thumbs Up
Post #241981 11th Feb 2014 5:32pm
mjdronfield
Just spoke to my local LR dealer about something else, and remembered the newer bolts being available, which cannot be undone without opening the lower tailgate.
The correct part number is fyp106392 but only available in a pack of 10 and with some discount I got, will cost me £3.50 odd. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #284285 3rd Oct 2014 5:01pm
