Home > Technical (L322) > TDV8 Head gasket failure / warranty |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 |
Sorry to here of your problems.
8th Oct 2013 4:57pm |
The other problem is if your head gasket was leaking before it blew then you could of leaked water into the oil paths and had water contaminated oil circulating around your engine without your knowledge while you drove. This might explain the low coolant warning but again for this to have come on there could have already been a fair quantity of water pumped into your engine already. So you could have driven miles without any knowledge of this until the catastrophic failure occurred.
8th Oct 2013 5:08pm |
xjr264 Member Since: 08 Oct 2013 Location: Bristol Posts: 5 |
Thanks for your reply, shoudl also mention that we've had trouble from day 1 really. A week after picking the RR up, the check engine light came on, turned out to be a fault with the EGR valve and also an injector. 2 weeks after that the air con blew a hose! So in the 3 months of owning the car, I've had about 5 weeks use of it!! |
8th Oct 2013 6:19pm |
So did they replace the EGR valve under warranty?
8th Oct 2013 6:30pm |
Just playing the Devils Advocate here but the engine may have been fine at the date of purchase. Any number of related or unrelated things could have caused the Engine Failure. How far back to you go in the blame game?
8th Oct 2013 7:38pm |
Gary while I appreciate your side of things ie: selling cars. I think in this case only having 5 weeks use out of the car in 3 months of ownership and the fact the check engine light came on after only 1 week of ownership and diagnosed EGR valve replaced and injector etc and aircon hose blowing, this does not appear to be a car that's been well prepared and checked thoroughly before sale. You could argue that the warranty should cover some things but it certainly shouldn't cover pre-existing issues. In this case I suspect the car was bad from day one and it was only a matter of time before something else went wrong, and in this case it took out the engine completely.
8th Oct 2013 8:00pm |
The list being an EGR Valve and a hose blowing.
8th Oct 2013 8:10pm |
It should also be noted that Dealers make a choice when selling cars:
8th Oct 2013 8:19pm |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
Hi xjr264, sorry to hear about your problems. PM sent. |
8th Oct 2013 8:24pm |
Gary your list seems a bit short, the actual list as described by XJR is EGR valve, fuel injector, aircon hose, and most importantly the head gasket. That's a lot of bad luck. And don't forget the car was only available to him for 5 weeks out of over 12 weeks due to faults etc.
8th Oct 2013 9:43pm |
Don't get me wrong its not a straight case of blame. It is possible the dealer did check the car correctly and bad luck could play a part in this case. The dealer could have done nothing wrong, but the point is the consumer has rights and blame or no blame unless the faults can be proven to have been caused by the new owner through neglect etc, then the responsibility lies with the dealer.
8th Oct 2013 9:55pm |
mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178 |
I may be missing something here but I assume the other faults were put right & I agree the onus is on the warranty company. However I have never in 20 years of building engines including race engines ( mainly Japanese) heard of sudden headgasket failure wrecking an engine with out prior symptoms or the engine being driven on after it has started to overheat. A warning to all, temp gauges or warning lights are there for a reason. I do hope you can get some recourse through the warranty company but no dealer could for see headgasket failure unless it had already failed but you would have surely been back complaining of loss of coolant? do not get to despondent though you can get it replaced for a lot less than 8k you just need to trawl the internet. All the best though & hope you get it sorted. Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
8th Oct 2013 10:17pm |
No we should not be encouraging him to request a refund.
8th Oct 2013 10:56pm |
I agree with you gazzellio, A dealer sells a car in good faith using a reputable warranty company what more can be done? Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
8th Oct 2013 11:04pm |
