Home > In Car Electronics (L322) > Bluetooth in my 02 L322 Vogue |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1516 |
Ok, I've looked at the diagrams and think I have worked it out based on the above thread. Now to go and do it.
21st Sep 2017 6:20am |
I've shorted the appropriate input wires to the VRM to the output wires and it's looking good so far.
21st Sep 2017 11:34am |
It's working. Thank you all.
22nd Sep 2017 2:44am |
Hmm, the poor quality may have been due to a flat battery! Did the ULF drain the battery overnight? Ron B. VK2OTC
22nd Sep 2017 5:17am |
With a charged battery it seems OK. What is noticeable is when the phone rings, it has a very pronounced click before each ring.
23rd Sep 2017 12:07am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7629 |
That's good news then. When I had a really old Sony mobile I used to get text messages on the car screen too, but that went away when I changed phone to a later one...
23rd Sep 2017 7:21am |
horsedentist Member Since: 23 Jun 2017 Location: london Posts: 158 |
I didn't bother with the pairing button in the front just put one in the back compartment once paired it remembers the pairing even if you take the battery lead off. I have nav coder too so I can pair with that if need be. If you have low volume I can recommend adding a little amp though. |
23rd Sep 2017 8:49am |
I was wrong. I didn't give it enough time. My iPhone 5 transferred my address book. There's just too many entries in it. Ron B. VK2OTC 2004 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
24th Sep 2017 2:47pm |
My iPhone 5 worked fine. If you select phone on the steering wheel the track up down scrolls through the phone book on the single line display under the speedo.
24th Sep 2017 3:00pm |
Or just set voice commands for the common numbers like "Dial Home". Don't need to use phonebook or take eyes off the road at all then.....
24th Sep 2017 3:04pm |
Yes, I've done that. I was initially confused in that I thought it would be like the iPhone where one asks for the name as saved in the phone (not that the iPhones have ever understood my requests - the Rangie does) and it would read the iPhone contact list. Ron B. VK2OTC
25th Sep 2017 12:01am |
I looked at the phone eject box and decided to mod it rather than replace it. As noted earlier, I incorporated the switch in the box to become the pairing button.
1st Oct 2017 10:03am |
Is it possible to clear the ULF of stored phone numbers?
9th Jan 2018 10:07am |
vitopresto Member Since: 28 Nov 2021 Location: Paris Posts: 1 |
@p38arover
24th Jan 2022 10:15pm |
