Home > In Car Electronics (L322) > Bluetooth in my 02 L322 Vogue |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Hello Pete and welcome....
21st Oct 2013 9:19pm |
Petewake Member Since: 21 Oct 2013 Location: Coleraine Posts: 11 |
Hi Mate, Yeah I have tried searching for Bluetooth and nothing. But will search around the forum for a while and see what I can find for sure.
22nd Oct 2013 8:20am |
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 |
There are quite a few posts on Bluetooth connection on here. Searching will bring most of them up. Just make sure you have a working BT module in the boot. The previous owner of my FFRR took his one with him I guess he bought another FFRR. Bushy
22nd Oct 2013 9:57am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7623 |
Bluetooth was never available on the earlier cars, so it must have been added after. Its either using a BMW ULF module on the end of the black 54 pin connector in the boot (having been rewired) or its an aftermarket kit.
22nd Oct 2013 10:04am |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 |
If yours is fitted with BT as standard then you should have a "pairing" button at the front of the cradle in the centre console, under the arm rest.
22nd Oct 2013 10:10am |
Bluetooth was never available. As standard or an option on the cars with BMW electronics, pre-touchscreen.
22nd Oct 2013 10:19am |
Guys,
22nd Oct 2013 2:02pm |
Bottom left of the third image looks like a Bluetooth ULF module.
22nd Oct 2013 2:17pm |
As Budgie says, ULF is fastened vertically in the bottom left of your last picture.
22nd Oct 2013 2:58pm |
Hey,
22nd Oct 2013 4:52pm |
The voice control from the steering wheel works no worries if that is to do with the ULF module
22nd Oct 2013 4:54pm |
The button on the steering wheel never worked for pairing with mine.
22nd Oct 2013 5:20pm |
Thanks that is great info, I will have a look at those other posts and see if I can sort it.
22nd Oct 2013 5:44pm |
Just a quick one,
22nd Oct 2013 5:50pm |
