Home > Wheels & Tyres > 255/50/20 Tyre Reccomandations
Nappler
2003 Range Rover Vogue 4.4 V8 Java Black
I just would like some tyre reccomendations as I'm looking to change mine, some snow and off road ability would be good, it seems to be a size that doesn't offer much in the way of good tyres though.
Post #219051 27th Oct 2013 1:38pm
Rosco
I have just put on General ATs 275/45/20, same rolling circumference as a 50 profile, very pleased with them so far Thumbs Up 2013 L405 Autobiography Baltic Blue
2007 L322 Vogue Buckingham Blue
Post #219063 27th Oct 2013 2:09pm
Vogue
Me too, they look fantastic, road noise is up a bit but not unbearable - concrete road surfaces are the worst. They are the only 20" AT tyre that fits, almost the same size and is speed rated for the RR. Fuel consumption seems to be slightly up but then there are chaps on the D3 forum getting around 50k miles out if a set, so this offsets the fuel - especially since the Scorpions on mine were goosed at 11k on the front & 16k on the rear!
Post #219090 27th Oct 2013 5:58pm
Rosco
Agreed, thanks Vogue for the heads up on the ATs, well chuffed as they say Thumbs Up 2013 L405 Autobiography Baltic Blue
Post #219098 27th Oct 2013 6:32pm
Nappler
Thanks, I will look into these, I was thinking of going for a set of Scorpions but if you can get a set of Grabbers on 20s those would definately be preferable and I expect cheaper too.
Is there no difference at all for putting these on instead of 255 50 20s?.
Post #219099 27th Oct 2013 6:36pm
Rosco
Would definitely recommend Nappler Thumbs Up No experience personally of life expectancy as yet but based on forum members shgould be good Thumbs Up 2013 L405 Autobiography Baltic Blue
Post #219100 27th Oct 2013 6:40pm
Vogue
No problem at all fitting them and no negatives - really good on flooded roads as well. I hit a flood last week and no aqua planing which surprised me - I put it down to the 11mm tread depth clearing water, I would have expected the old Scorpions to have struggled. Plus they were only £164 a tyre fitted and balanced Thumbs Up
I also like the look of them - the std 255's look a bit too feminine on a mans car Laughing
Post #219106 27th Oct 2013 6:54pm
Googsy
What about 265 55 20 or 255 55 20 for more comfort. The 45 profile I always found a bit hard when I had them on my disco. I know speedo would be out but not by much. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #219110 27th Oct 2013 7:09pm
Vogue
That profile is getting into L405 diameter territory. Not a problem but it will raise your gearing, fuel consumption will go down but it will also negatively affect acceleration - if that matters.
Post #219113 27th Oct 2013 7:13pm
Baron
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
I have been running a set of L405 wheels with 255/55/20's on and while they were comfortable and quiet and the slightly larger diameter corrected my speedo reading they did slightly raise the gearing. Not by much but it was occassionaly noticable. I only realised this when I refitted my original wheels with 255/55/19's on. Not a show stopper but when the 20's wear out I'll be fitting 255/50/20's to retain the original design diameter.
Just another point of view. 4.4 TDV8 Vogue Baltic Blue MY11
Post #219119 27th Oct 2013 7:27pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I have been very happy with Toyos since ditching the Continentals which cost a fortune and wore out a little too rapidly for my liking.
Will be replacing with Toyos when the time comes. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #219332 28th Oct 2013 4:54pm
AJS4X4
Re: 255/50/20 Tyre Reccomandations
As a few have said the General AT is available in 275/45x20 and Cooper LTZ also but on back order.
We have the General AT 275/45x20 in stock as well as all other sizes and I notice you are in Surrey so we can't be that far from you. Thumbs Up Andy....
www.ajstyres.co.uk www.ajs4x4.co.uk
01737 241370.
Always best to phone first.
Post #219595 29th Oct 2013 9:58pm
Vogue
@ Nappler I would give Andy a go on these tyres, I would have bought mine from him given the good feedback off all Martin's Forums - but a round trip of around 800 miles when I needed them wasn't economically viable Thumbs Up and my local fitter wouldn't fit tyres sourced elsewhere via mail order ....
Post #219600 29th Oct 2013 10:35pm
johnboyairey
I just fitted a set of 20's with the grabber AT yres, they have huge looking tread depth, and look quite angry/noisy tyres. but they seem to me to be really quiet, went for a 200 mile trip on them today, 80mph etc -so much quieter than my old 22's that i'm retiring. I came here coz I was curious of the tyre size for comparison to standard size. I will post a pic
yes, they do look angry, but they drive so well. I don't really need to test mudplugging capabilities etc, but for the money, I will get a good few mile from them. lastly, road tyres these days, seem to have less tread at the shoulders. ie they will wear quickly, and they cost like 250 upwards, have a look in the tyreshop, and when I search for tyres I see Pirellis and similar top brands at 400-500 each. for 8mm of rubber. less at the edges. are we being conned? p.s/ I'm not being a tyre-tight-wad here.
Post #224022 20th Nov 2013 12:00am
Mist be the sound deadening on the ff. i have a set on one of the hilux and they are noticeably noisier than the eqivalent bridgestones on the other lux. I hear them driving past as well as from in the cab and the at's seem noisier from outside too.
Not tried them on the ff but would be a bit agressive for my purposes in any case. The wranglers on my 19's copes with all the cold stuff last year, plus a bit of light muddy.
That said the grabbers on the lux coped well for the entire year conditions wise. And do look chunkier Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #224040 20th Nov 2013 8:51am
