![]() | Home > Technical (L322) > trans failsafe prog |
alib123 Member Since: 29 Dec 2013 Location: essex Posts: 20 ![]() ![]() ![]() |
anyone have any ideas?? |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1039 ![]() ![]() |
Your ‘bass speaker’ rumble may well be caused by wear in the torque converter lock-up clutch but this doesn’t usually cause other issues with the 5HP24 and you could potentially continue for thousands of miles yet with the lock-up clutch in this condition and not cause any damage.
Thanks for your help and info Phil. I have followed your advice and can report the following.
Sorry forgot to mention, can select hi low with no problems (obv not when locked in trans safe) and battery is fine. |
If your transmission fails safe to 4th gear then it would appear that your A-clutch is okay. Fluid temperature dependency usually indicates internal seal leakage. I think the best thing to do next would be to get the codes read, but you would need to use a high level diagnostics kit like Testbook/T4 or Autologic to get the Land Rover specific transmission fault codes, and not just some generic OBD kit
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902 ![]() ![]() ![]() |
Mine showed up this message, only did it once a few days ago. All I did was charge the battery up on trickle charge, was told to check battery, even though it is new.
Update, looks like its a problem with the hydraulics and the b clutch. Ive been quoted £2500 plus vat for a full rebuild. I cannot afford that so does anyone know or recommend anyone in essex/kent to do the work? |
Do you happen to know what fault code led them to believe there was a problem with your B-clutch? I’ve never heard of a 5HP24 'failing safe' to a gear that required the clutch that it had just detected a fault with. The B-clutch is used in 4th gear & 5th gear, of course.
Hi Phil, I dont know the fault code yet, sorry. He just said that it locked into 3rd on his test run and when he diagnosed it it said hydro prob and b clutch. Il try to find out more. Im also looking for an exchange unit as this maybe cheaper option thsn rebuilding mine |
Could it be gearbox overheating that would explain the hard driving factor. I have known these symptoms before.... |
