Home > My Range Rover > Something's not right... |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6355 |
Hmmm. It came back from the dealers the other day not having had the brakes done and since, it has got a very annoying and noticeable screeching noise at low speeds. (people stopping to see where the old rust bucket heap of Sh*t is that must be making the noise...very surprised to see its me!)
7th Jun 2010 7:26pm |
Sounds like the pads rubbing the disks due to warping of the disks. Is it about one screech per wheel rotation when going slow with windows open?
7th Jun 2010 7:29pm |
Yup, the screech is cyclical, like it could be a spot on the disc that rubs on rotation. What makes me think it is not the discs though is the dealers took the brakes apart and said they look 'ok' but not great. Mind you, the screech got worse since they took the brakes apart and put them back....Who knows. Pads replaced the wrong way round to the way they came off?
7th Jun 2010 7:37pm |
I had trouble placing the sound but it was the discs and as the dealer "played" with your brakes I am pretty sure it will be the re-seated pads. Get them to re-do them until the screech disappears mate.
7th Jun 2010 7:56pm |
I had a look underneath and can't see anything out of place or untoward.
7th Jun 2010 8:50pm |
being 4 wheel drive, I'm not sure its possible, never actually tried after all these years! Discovery 4 HSE
7th Jun 2010 9:24pm |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 |
Can't understand your dealers reasoning for not changing the brakes ? - assuming you mentioned to the dealer that you had braking issues and looking at the photo you've provided (which show an uneven, contanimated and worn brake biting surface) - Seems a bit strange?
7th Jun 2010 9:44pm |
Delamo,
7th Jun 2010 10:02pm |
specman Member Since: 20 May 2010 Location: Fife Posts: 250 |
Your discs are pretty knackered mate to be honest, I would be changing them PDQ.
7th Jun 2010 10:03pm |
As per my original reply - new discs and pads mate. |
7th Jun 2010 10:46pm |
GKP Member Since: 01 Aug 2009 Location: Hants Posts: 75 |
Can you pinpoint the noise to front or rear of the car? I've had a terrible time in the past chasing a screech/squeal which was a damaged backplate on the rear brakes. It came into contact with the edge of the 'handbrake drum' every rotation and no amount of bending or reshaping would get it to clear.
8th Jun 2010 1:39pm |
ukrangie Member Since: 20 Jun 2009 Location: Kent Posts: 520 |
Would it be worth getting your brakes sanded back whilst you wait for them to be replaced? If it is only light scratched it may work? Paul
11th Jun 2010 9:30pm |
The car went in today. I decided that I should throw some money and TLC it's way rather than my usual 'try and find the cheapest fix'.
11th Jun 2010 10:15pm |
jayzee Member Since: 14 Oct 2009 Location: UK Posts: 342 |
Bit of a stinger Adam, but you can't put a price on safety Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD! |
11th Jun 2010 10:48pm |
