Home > Maintenance & Mods (L322) > Towbar Electrics |
IIRC as long as its the correct module for your vehicle thats all that matters.
20th Feb 2014 2:06pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
Don't forget you'll need the extra relay and wiring for the caravan fridge/charging system.http://www.westfalia-automotive.de/fileadm...391101.pdf Ian |
20th Feb 2014 6:44pm |
module is the same for all of the wiring options.
20th Feb 2014 8:14pm |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 |
Thanks for the help guys 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!) |
20th Feb 2014 11:31pm |
Another question - forgive my ignorance but I am still learning about my FF.
23rd Feb 2014 11:54pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
If you have touch screen nav then you simply need the 05-09 module |
24th Feb 2014 12:02am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4245 |
I need to do the same on mine (2011 4.4). It currently has a single black socket but want to convert to 13pin.
15th Oct 2018 12:48pm |
On a 2011 you only need to order the loom sir... There is NO module on 09> Rob
15th Oct 2018 1:07pm |
Cheers Craig
15th Oct 2018 4:25pm |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
PF Jones sell the wiring looms |
15th Oct 2018 11:40pm |
16th Oct 2018 2:18pm |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
Some have had a good experience with PF Jones. I, and lots of others, didn't.
16th Oct 2018 3:28pm |
Genuine 13 pin on its way from Dan at Duckworths Only fitting so I can charge battery with the Ctek and adaptor from forum store Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" New Defender D300 90 1974 Series 3 Lightweight = "Millie" My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
1st Mar 2019 9:31pm |
Nick591 Member Since: 04 May 2017 Location: Charfield Posts: 193 |
Forum store? Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
2nd Mar 2019 5:20pm |
