Home > Maintenance & Mods (L322) > Cold start |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7631 |
Not got an SC myself, but if the engine management light has been on, there should be a fault logged.
25th Feb 2014 7:01pm |
Beanoraa Member Since: 27 Aug 2012 Location: N Ireland Posts: 18 |
Thanks mjdronfield for the reply somebody else I was talking to said something about the coil I will get that looked at. Going away on holidays for a few weeks so it will have to wait till I get back. Don't know if fault is logged ,when I press the button on dash it says check ok. |
25th Feb 2014 7:12pm |
The fault will be logged on the engine managements system. The cluster won't show it to you. You will need to get a garage to plug a diagnostic tool into it and read the faults off.
25th Feb 2014 7:21pm |
Ok thanks will get my garage to plug a diagnostic tool into it they charge £30 not to bad |
25th Feb 2014 7:27pm |
Could be worse.
25th Feb 2014 7:31pm |
Will let you know in two weeks time |
25th Feb 2014 7:37pm |
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 220 |
Did you find a solution as my SC has developed a similar fault.
7th Jan 2015 9:04am |
