Home > Maintenance & Mods (L322) > Something leaking?
jaipal2004
Something leaking?
Hi,
over the last couple of weeks I've noticed a small pool collecting under the car just behind the rad. It doesn't always happen but it seems to be more so than not! There doesn't appear to be any pattern to it either that I cna see.
I have collected some of this liquid on my finger - there's no smell and it's definitely not oil although it does appear to have a very very slight reddish tinge (that could be due to the road surface or what it's 'touched' on the way down. When looking at the underside of the car the droplets seem to collect on what looks like a cross member behind the rad.
Car temperature is fine, nothing else weird happening I think although yesterday it seemed to have low power - almost like something was slipping. I pulled over, turned off - put it to petrol (mine is LPG'd) and was fine - even managed to change back to LPG shortly afterwards.
It's a 2004 4.4 v8 FFRR
Still got the issue of not being able to read the diagnostics so need to take it back to Jamesons and get that sorted too!
Post #249146 19th Mar 2014 10:54am
johnboyairey
check fluid levels
when its cool undo the rad expansion tank, check the level, see manual for guidance. the bobbing 'float' will tell you if you are losing water, (or mixed coolant). if its up and fine, dip finger or a cotton bud, and compare colour to what you found. if its more red than pink (from the floor) , check you steering fluid, again, see manual. (round bottle) my hunch is a water/coolant leak. sort of common to have an old radiator start to corrode and leak (on this model and age). not expensive, (£130 new pattern part) and no more than 1hr to change. its a DIY job if you are competent. you would need to read up on how to remove viscous fan first. check fluid levels
you can buy a gallon of pink coolant from euro car parts for £20 to replace your fluid or a smaller to top up. 50/50
Post #249165 19th Mar 2014 11:51am
possibly condensation from the a/c.. ... - .- -.
Post #249167 19th Mar 2014 12:21pm
kirton
England 2006 Range Rover Autobiography 4.4 V8 Zermatt Silver
Most local garages can do a pressure test on your cooling system and if a small leak is found then ten quids worth of K-Shield should do the trick.
Post #249206 19th Mar 2014 5:56pm
I wouldn't put K-Seal anywhere near the cooling system. Yes it will bung up a small leak, but it will also bung up your cooling system and cause lots of heavy duty expense.
Repair it once...repair it properly
Post #249216 19th Mar 2014 6:56pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
+1 Thumbs Up Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #249241 19th Mar 2014 9:02pm
Bushy513
United Kingdom 2003 Range Rover Vogue Td6 Monte Carlo Blue
It sounds too far forward to be the AC as that normally falls around the Gbox. Out of curiosity what colour screen wash do you use? It could be coolant or power steering fluid. But these normally have a thicker viscosity ( unless you're running very weak coolant )
If you have been using the screen washer and one of the connections has fallen off or pipes has a slight cut. This could cause a small leak. Just a thought.
But if in doubt get your system pressure tested and get a good head torch and try and chase the leak as high as you can see. Good luck Thumbs Up Bushy
2003 RR Vogue Monté Carlo Blue
Post #249254 19th Mar 2014 9:45pm
jaipal2004
Only just had a chance to check back and noticed quite a few of you had kindly responded Smile Thumbs Up
I'll check and let you know - will try and drop it off to a garage later.
I've not noticed any issues with the car overheating/ temp gauge showing excessively high so wouldn't have thought it was coolant?
Cheers all Smile
Post #251686 31st Mar 2014 11:39am
markcartlidge
United Kingdom 2002 Range Rover Vogue 4.4 V8 Java Black
Isnt coolant supposed to blue on this age, mine is?
Post #251714 31st Mar 2014 1:50pm
jaipal2004
Hi,
checked the coolant level today and it was quite low - I had to use a 1litre bottle of ready-mixed cooland to bring the float back up to the max level.
My usual car spares place wasn't open and therefore I had to use blue coolant - I guess there's no material difference and it's just the colour??
Will check the level later today/ tomorrow morning after it's parked up and see if it's dropped again.
Cheers
Post #251866 1st Apr 2014 9:54am
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
there is a difference in the coolant, you can mix green and blue and can mix red and orange, but you shouldn't mix red/orange with blue/green. I have heard they can react with each other and gunge up the cooling system 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #251893 1st Apr 2014 1:20pm
jaipal2004
oh cr@p!
How do I know for certain what colour mine is originally? I've definitely topped up 1l of blue so have I Censored something up?
Post #251894 1st Apr 2014 1:22pm
jaipal2004
Seems that the leak is not there this morning!
Make of that what you will?!
Post #252177 2nd Apr 2014 11:57am
