Home > In Car Electronics (L322) > mk4 SAT NAV- Can't turn off speed cameras |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
I used to be able to turn the camera alerts on and off, but I no longer can. I can't remember whether this is a feature of the map disc or the V.32 software.
19th Mar 2014 1:47pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34918 |
not sure if this is the correct procedure but do you not have to go into the french language to do that.. ... - .- -.
19th Mar 2014 2:34pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7632 |
Only have the original v32 firmware myself, but I believe the speed cameras are points of interest on the modded firmware. Could be wrong...
19th Mar 2014 3:59pm |
It used to show "on/off" in the config menu. When I turned it off, the language changed to French. I no longer have the option to turn it on and off though? |
19th Mar 2014 6:03pm |
Anyone? |
28th Mar 2014 9:21am |
Andy, pm matt stevenson, he seems to be in the 'know'... ... - .- -.
28th Mar 2014 9:37am |
Can you not reload the pukka BMW firmware and start again ?
28th Mar 2014 9:42am |
........I'll have a quick look........and see a differing view on whether it'll let you downgrade to a lower version number...
28th Mar 2014 10:06am |
I bought the mk4 unit off a forum member. It needed a new laser which I did myself. I then used matts software and it worked fine at first. Now, I cant turn off the audible warning. Also, I think the scale has changed- I'm pretty sure I could take the range down to 75yds. It's now 125yds. |
15th Apr 2014 4:20am |
Pretty sure 125 yards is the lowest scale mine shows. 2011 Range Rover Vogue SE 4.4 TDV8
15th Apr 2014 7:59am |
