Home > Technical (L322) > HELP - misfiring and cutting out....experts baffled
ALEX1
Hi guys. I had this problem now for the past 3 weeks and so far 2 garages cant figure out what the problem is. On day after filing up with fuel, the car just cut out and wouldnt rev. AA came out and diagnostics showed it was cam shaft sensor. Went to specialist who said it was a fuel related problem (filter or pump), but after a flush of the fuel pipes the car was fine.....4 days later on a motorway it started backfiring, and went to stall. After a 30 minute rest it was ok but the next day it again cut out and left me stranded. Off it went to a BMW expert who diagnosed cam shaft sensor fault. It got replaced and the car was fine for a few days until it cut out again. ! Back to the BMW garage it went and they found that the sensor suppied was faulty and a new one was installed. Fine for a few days, and just on my way home tonight it nearly cut again....
Has anyone got any idea what this could be?? Petrol 4.4, with 130k on the clock
Post #253913 11th Apr 2014 9:31pm
Winchester101
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
This might be a bit late but where did you buy the petrol
I've had problems in the past with supermarket petrol 1994 softail full stars n stripes custom harley davidson
Post #253970 12th Apr 2014 9:06am
ALEX1
No its not the petrol as i have filled up several times by now from different places. I am guessing that it could be the fuel pump but dont know how to narrow it down
Post #253971 12th Apr 2014 9:12am
I take it they plugged it in? There is nothing that can't be fixed with a hammer😜😜
Post #253973 12th Apr 2014 9:27am
ALEX1
The car has left the service garage 3 times now running fine - but after a few days the problem appears as if its something that just builds up with use.....but i cant figure out what
Post #253976 12th Apr 2014 9:34am
I think the AA man may have been right... It takes 75 miles for the engine to fully learn new adaptions and if the garage reset the adaptions then it would behave for a few days...
Change specialists?
Post #253995 12th Apr 2014 11:50am
ALEX1
The camshaft sensor has been replaced but the problem pessists.
Post #254000 12th Apr 2014 12:13pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
If the fault persists then maybe a wiring issue up to the sensor.
There are two sensors though, one for each bank, have they replaced the correct one?
Should be easy enough to check, just swap the two sensors around and see if the fault moves bank. If the fault stays where it is with a known good sensor then it's probably a wiring problem or an issue elsewhere that side. If the fault moves then it's a dodgy sensor.
As Cam-tech says, if they can't work that one out it's time to change 'specialists'.
Post #254023 12th Apr 2014 2:16pm
Rosco
I would check instrument cluster, sounds daft but that was my issue, needed to be replaced and apparently only by a main dealer
Post #254031 12th Apr 2014 3:31pm
ALEX1
Is it definetly not a fuel pump issue? Why does it run ok when the mechanics have had a fiddle with it and then start playing up a few days later?
Post #254033 12th Apr 2014 3:43pm
bwelton
United Kingdom 2012 Range Rover Vogue SE TDV8 Zermatt Silver
Hi ALEX1,
Did you get to the bottom of what was wrong ?
Thx
Post #428338 19th Feb 2017 11:38am
andrew-a
My local garage could not diagnose it so ended up having to take it to the main dealer. It was the fuel injectors - 4 out of the 8 had to be replaced. Dealer quoted £2k for the job! Yikes!
Post #428344 19th Feb 2017 12:05pm
Ian c2
United States 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Change specialists?
I find setting the cruise to approx 59mph has them reset in about 20 motorway minutes Wink
45 minutes idling will clear any that don't reset after that .
Having injectors tested and ultrasonicLly cleaned has worked for me in the past as an alternative to replacement
Post #435633 22nd Apr 2017 8:28pm
