Home > Technical (L322) > New windscreen at stealers ? Advice please |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2217 |
On mine the spec is screen plus heated plus acoustic plus the sensor for the wipers so the full spec and made by pilkington same as the LR one |
8th May 2014 6:09pm |
Scuttle and wipers have to come out!
8th May 2014 10:24pm |
Standard pilkington it is
9th May 2014 8:08pm |
All done by Autoglass took a while as they had wrong one apparently the heated screen terminal is in a different place ?? not sure about that
13th May 2014 2:40pm |
Had windscreen fitted by Autoglass and then put car in for mot at stealers and asked them to snag the install - all the clips on the a pillars were broken and the top seal had been bonded into the windscreen. Noise was none too good either. By the way cost of clips and repair at stealers was £95 +Vat.
2nd Jun 2014 10:41am |
