Home > Technical (L322) > air bag light. |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
Do not muck about with the airbag! It can cause serious injury if it goes off inadvertently. Take it to someone who knows how to deal with them! Previous cars:
2nd May 2014 11:15am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
i had an intermittent light on my td6 which was due to an occupancy sensor failing in my passenger seat..this failure was diagnosed by someone moving about in the seat and the light flickering.. ... - .- -.
2nd May 2014 11:24am |
paul r Member Since: 27 Feb 2012 Location: Nantwich Posts: 213 |
This almost definately the connector on the air bag module. I just need to know how to get to the module to check the connector.
2nd May 2014 11:37am |
there are WM downloads in the wiki.. ... - .- -.
2nd May 2014 11:46am |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 |
I would endorse what APPJ62 said above
2nd May 2014 2:29pm |
Removing the negative terminal on the battery and leaving for 30 mins is a good way to disable the SRs system.. |
6th May 2014 2:00pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2025 |
(my car 2002 v if you know someone with an RSW allcomms diagnostic. you can get an idea of what is calling the fault. I bought my car before it was an mot fail on the SRS airbag. using said cable, it was coming up with the battery connector blow off sensor. however after changing it, it was same. I then removed centre console to reveal the airbag main brain. (its possible to lift the rear just high enough, but I would recommend removing it) the airbag box is about 4 inches square and about 1 inch thick. belive it holds faults, and can be troublesome to reset. (for crash analysis by insurance etc)
6th May 2014 11:19pm |
L322RR Member Since: 06 Oct 2011 Location: Düsseldorf Posts: 51 |
Hi, I have the same problem (confirmed by the GAP tool). How did you solve this? Thanks |
7th May 2014 7:56am |
replaced the sensor, cost was around £90 at the time...the seat trim comes off and the sensor is revealed.. ... - .- -.
7th May 2014 8:00am |
Did you do it yourself? Is it difficult to get the trim off, do I need to remove the seat?
7th May 2014 8:02am |
my son did it..the seat comes out very easily, then the clips ,which are under tension come off and the seat cover is pulled back...the fiddlelist bit was getting the clips off. ... - .- -.
7th May 2014 8:05am |
I forgot to reply to this, but it was my battery that was causing the issue - thought i'd update incase that someone else had the same issue . Replaced the battery and everything is fine.
24th Apr 2015 7:51am |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
The system has a capacitor to fire it in the event of a loss of battery power, however disconnecting the battery, or removing the fuse and letting the capacitor discharge for 30 min disables it. But yes it is always a good idea to treat these things with caution. |
24th Apr 2015 9:00am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
For what its worth... Leave these kind of jobs to the professionals... |
24th Apr 2015 9:50am |
