Home > Maintenance & Mods (L322) > Water in footwell
Duke Thrust
Water in footwell
Chaps,
Getting a very small amount of water ingress into the drivers footwell after heavy rain - I initially suspected the seals aound the windscreen but would it not be bonded in?
Any suggestions?
Post #22944 22nd Jul 2010 8:21am
Fox
Watering Can/Hosepipe and an assistant.
Move round the car slowly.
On different LR products I've seen it be the door seals, windscreen (yes, it's bonded) and sunroof.
/the off topic bit/
I remember an old sierra that I couldn't find the leak on. I drilled some holes in the footwell to let the water out again. Smile
Post #22946 22nd Jul 2010 8:30am
dan_uk_1984
Could it be a blocked sunroof drain tube?
Post #22947 22nd Jul 2010 8:44am
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
Ah - the Defender solution - ensure that the exit hole/s area > entry hole/s area ... Laughing
Post #22951 22nd Jul 2010 11:07am
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
check the AC system.
I also had the same problem, and it turned out to be a loose tube from the AC.
Post #23429 28th Jul 2010 12:30am
