Home > In Car Electronics (L322) > Irregular HVAC behaviour |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
I recently got my aircon performance checked and regassed at Halfords, as it had'nt worked at all from when I got the FF a year and a half ago. They have a deal on at the moment where they'll do a free performance test and check over for free...if it passes that, they regas the aircon for £49.00. That's all it cost me and now I've got full aircon.
10th Jul 2014 8:17pm |
From what you describe it's possible the ac system isn't able to read the internal temperature in the car due to the internal air temperature sensor being insulated due to dirt build up. The sensor is located on the back of the upper section of the central lower dash below the ac control knobs. You can see the small intake grille for the sensor next to the manual vent settings. The sensor works by a small integral fan drawing air from the car thro the grille so it's also possible the fan is not functioning. |
10th Jul 2014 9:01pm |
666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108 |
Thanks for the replies. The air coming out is cold and I can chill the car so I don't think it needs gassing. Was all serviced at land rover dealer last year.
10th Jul 2014 10:07pm |
After several hours in the car I have more of an understanding of the issue. The manual heater buttons for the face, feet, windscreen don't make any difference to air flow. The fault is intermittent. Some times the faces vents work and other times they don't. The fan speed however does, I can hear it working but it's not pushing air out with any forces on full speed. Got a bit warm today. Could this be the FSR? 2012 4.4TDV8 VSE
17th Jul 2014 9:36pm |
Mine did that for a while, i cleaned the little vent out with a can of air duster from a plumbers merchant, compressed air in a tin with a straw nozzle.
19th Jul 2014 8:22am |
Thanks. There was a lot of dust around the little grille, will try the can of air !
19th Jul 2014 1:31pm |
Tried cleaning the temp sensor with compressed air but no change.
28th Jul 2014 1:19pm |
