Home > Wheels & Tyres > Tyre Pressure |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
Normal load 33 front, 36 rear.
12th Jul 2014 9:16am |
Vorbis Member Since: 19 Jun 2014 Location: Pebmarsh Posts: 147 |
Well just set them at the above and they look a bit flat |
12th Jul 2014 10:25am |
What's the spare supposed to be at? Its at 36 and I'm getting warnings |
12th Jul 2014 10:49am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35114 |
if you have nexens fitted then they do look flat when at the correct pressure... ... - .- -.
12th Jul 2014 11:20am |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
33 front and 36 rear refers to car with 4 people and light luggage some on here put less in as in my case its mostly only 2 of us. Therefore i put 31 front and 34 in the rear and it makes for a more comfortable ride. Present :2008 TDV8 HSE
12th Jul 2014 11:23am |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
Vorbis...MD told me the spare has to be 45+ to stop TPMS warning...worked for me at 46psi GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
12th Jul 2014 12:04pm |
Thanks guys. If I see that warning light once more, I think ill get the 12 bore out and shoot the bloody things |
12th Jul 2014 2:19pm |
Get an IID tool...you wont regret it, especially when you switch that B y TPMS off GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
12th Jul 2014 2:37pm |
Is shotgun damage covered under warranty? |
12th Jul 2014 2:55pm |
Ok really fecking unhappy now. Popped to the local filling station to add more air to the spare. Thought I'd check the others again whilst I was at it. Pushed the air hose into the first tyre and the poxy bleeping valve snapped off
13th Jul 2014 7:17pm |
sorry to hear that paul, these metal valves corrode and do snap off very easily... ... - .- -.
13th Jul 2014 7:22pm |
Nightmare... feel for you... this problem is actually referred to in the buying guide
13th Jul 2014 7:28pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1695 |
Hey Vorbis - Halstead as in Essex..?
13th Jul 2014 8:11pm |
Well finally back home now What will a new set of sensors and valves cost me? |
13th Jul 2014 8:12pm |
