Home > In Car Electronics (L322) > Bluetooth install into a 2003/04 Vogue HELP!! |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Hi all, having installed a reversing camera into my 53/2004 Vogue, I thought that I'd try and get my head around the the issues of installing a bluetooth system into my ride. But I'm getting a wee bit confused as to how to go about it.
27th Jul 2014 6:05pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7635 |
I've gone the BMW ulf route as I wanted it to all be factory BMW fit.
27th Jul 2014 7:29pm |
The main reason for fitting the Grom is that I can link to my phone by bluetooth and at the same time I can hook up an Ipod. The cost is about £126, and it claims to be plug and play. That would seam to me to be about the same cost as a BMW ulf, without the rewire of the plug and also have the ability to plug in the Ipod and another source (2 Aux inputs), with out the need of additional modules.
28th Jul 2014 7:39pm |
Fair point.
28th Jul 2014 7:53pm |
I've looked into the Bm54 upgrade and its rather alot of dosh for a 3.5mm aux jack. If the Grom unit can be made to work, it will give me steering wheel control of the Ipod and the ability to take handsfree calls. How much info I get on the nav screen is a mystery!! The main point of confusion is, when you look at the manufacturer application list it only lists HSE without nav, but when you look at the X5 list it says it will do the nav (non touch). Surely we are talking about the same system???????? |
28th Jul 2014 11:42pm |
The systems are the same as in the E39 5 series and E53 X5. As you know, the setup is totally different from the standard HSE spec and one with nav. I think the non screen setup is referred to as a MID system if you look in the manuals.
29th Jul 2014 6:44am |
Right I've just taken the plunge and ordered the Grom bluetooth unit, it would appear that the confusion was being caused by the fact that the Americans HSE spec is not the same as the UK spec HSE, and that it comes with the non touch sat nav as std. Why can't they just have the same models as the rest of the world? It would make a lot less confusing
29th Jul 2014 12:47pm |
29th Jul 2014 6:38pm |
